No 4 wheel drive?
mmmansur
New to the forum, long time Ford owner. Currently, I have a 1993 Explorer, push button four wheel drive and manual hub conversion. The four wheel drive is not engaging. The indicater on the dash lights up, I can hear the all of the normal clicks telling me that the transfer case appears to be engaging in both 4H and 4L. I crawled underneath and tried spinning the front drive shaft by hand, it locks in when I put it in 4 wheel drive. I have pulled the hubs off and found one to be bad. Do both hubs need to be functioning for the 4 wheel drive to engage (I did try to swap them to the opposite sides, with the same result)? I am getting no unusual noises from the front end, so I don't think I have a major or overly pricey problem. Any advise would be appriciated.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
yes both hubs need to be engaged otherwise, the differential will just spin and no power will be sent to the good hub.
solution = replace bad hub.
