No injector pulse
Oldfordranger
Washington
Ford ranger
So I have a 1988 ford ranger 4wd 2.3L manual. I have no injector pulse. The fule pumps had no power so I hooked them up to a switch. I have no idea what to do or how this system works. I really want to drive this truck again. Please any help would be awsome. Thanks
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Hows this one mine, he didn't even say what engine it is!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Start with the basics. Have you gone through the fuses and relays? You say you hooked the fuel pumps to a switch, does that mean they now work but the injectors still aren't firing? How did you test the injectors?
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would back up two steps and figure out why the fuel pump won't run... for all you know the ECM could be bad. Does it have spark?
Oldfordranger
Washington
Ford ranger
I checked all the fuses and relays. The truck ran for 2 weeks after I fixed the fule issue. And i unplugged a injector and used a voltmeter and had some one crank the engine
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Cant test a fuel injector that way. Fuel injectors pulse to ground in terms of milliseconds (positive is always connected). A voltmeter can't read a pulse that fast. You need to use a noid light or more sophisticated testing equipment.
Will it start if you spray starting fluid in it?
Oldfordranger
Washington
Ford ranger
Oh okay I'll get the right tools. And I poured a little gasoline down the intake and it did run for 2 seconds
8,370
Test for 12v on any Red fuel injector wire, with key on
If no 12volt then change EEC relay, Brown base relay on inner fender
Unplug TPS(throttle position sensor) and see if it starts
If TPS is shorted computer will turn off injectors
Oldfordranger
Washington
Ford ranger
Awsome I'll get on that. Thank you
