09fx4guy
- Jan 10, 2010
- 176
- USA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- Pre Key w/ #1 Bars
- Tire Size
- 265/70R16
Hello Everybody,
I find myself today in another quandary. I am still working on my front end noise that I had posted about in an earlier thread, I have it isolated to either the sway bar end links or the inner tie rods. I have already ruled out the ball joints, checked them twice. My first spot to check is going to be the sway bar, and here is where my problem begins.
I was able to order the Moog sway bar links, but when I measured the sway bar for the frame bushings, it measures between 33 mm and 34 mm. The parts catalogs list either 27mm or 29mm sway bar frame bushings.
I was able to find a part number on the sway bar, which is F87A-5494-CC. This number does not correspond to a Ranger. There is no question that the bar came with the truck from the factory, since I am the original owner. I was hoping to call Tasca and see what that number corresponds to, but they are not currently taking phone calls.
I know that Energy Suspension makes a 33mm greasable frame bushing, which would be fine by me to use.
Has anyone else had the problem of not being able to find the proper sway bar frame bushings? Or rather, what have you used instead?
Any and all help would be appreciated.
