Oops! Oil in the PS,
Denisefwd93
74
South East PA
Most definitely a senior moment, OMG!
Grabbed the ATF, started putting in a couple ounces because we were moving the steering when the wheels are off the ground and and a lot of it ran out from wherever runs out of. As I started pouring it I saw it was a oil and stopped I'm guessing it's not a terrible thing I sucked it right out with small pump and put some ATF in but some of it was already in the system because I had started the engine.
Do I just remove and fill a few times to dilute the oil that's in there?
I would. Prestone makes a flush that I think I'd run through there too. Just to be safe.
Denisefwd93
74
South East PA
Will do, thanks!
