CrazyRN
- Jul 26, 2012
- 0
- North Carolina
- Ford
- Engine Size
- 2.3L
Ok, so I am totally new to this whole forum thing, especially in relation to trucks, or anything mechanical, lol. My son (17) has a 1997 Ford Ranger XLT 2.3L, that he's had for a little over a year. Yesterday, he had driven the truck 2 or 3 different times without trouble & later in the day he had went approximately 5 miles when he stopped at a red light. As soon as he attempted to take off at the light the engine died. It cranks (with a very subtle hesitation) & idles perfect & runs fine in reverse, but as soon as it is shifted into gear it immediately dies & the check engine light glows red. A fellow stopped by & tested something in the panel under the steering wheel & said he believes it is the torque converter "switch" & suggested I either find a good transmission mechanic (which I'm told we really don't have locally) or replace the transmission (CHA-CHING$$$!!). After doing some reading, I have found nothing about a 'switch', but rather a clutch, but also read that the solenoid is more likely to go out before the actual torque converter clutch itself. I also ran into some odd & end forums about a few with similar symptoms who had a blown fuse (in engine compartment) or something related to a sensor. I had to have the truck towed home so running it around to have it tested is not really an option. Only real mods are a cold air intake & some kind of fuel chip (?) that were added in January this year with no problems from either thus far. I am a nurse, not a mechanic, but I have previously (& successfully) torn the dash out of this truck & repaired the odometer gear, replaced dash lights, replaced the fuel pump & fuel neck, in addition to cosmetic work (lights, etc.) myself, just from reading online. So, with that being said, this may still be waaaay outta my league, but wanted to see if I could get some opinions to know which way to lean before I get hoo-dood out of a buncha $$ I don't really have. Any ideas???
