Prerunners B II under construction (finally!)
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Took a lot of prying to get it past the driveshaft and that lip on the firewall.
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
But considering I left the T-case and exhaust on it came out pretty clean.
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Separated at last:
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Started the teardown of the Exploder today. That rad may be too big for the Bronco. I mocked it into there and I'm going to have to get creative to make it fit. I dropped a '91 - 94 Sploder manual trans rad I had kicking around into it and its the same as the B-II one. The '96 AT rad is wider and puts the lower outlet right into the front of the steering box.
Oh well, "some assembly required" was implied when I took this on. :shok:
And another side project: the hood hinges from the Sploder onto the B-II. No more prop rod. :)
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Not much of an update but I'm kinda stuck. The rad support on the B-II is badly rotted out and I haven't had time to locate a replacement yet. I think I'm gonna just remove the front sheetmetal for the time being or at least until I can locate something better. Will a '91 - 94 Explorer rad support interchange? I can't weld so I can't just patch it.
The Exploder is coming apart slowly. I've started cutting wires I think will be useless on the B-II like airbag sensors. I'm going to leave the AC in it until the engines out then transfer it before the 4.0 gets stabbed into the Bronc.
I keep finding parts and parts vehicles I'd like now that stuffs apart and moneys tight. Ain't it always the way? lmao.
BTW, its definitely getting a SAS in the not too distant future and I've decided on the Chevy springs in back. :icon_thumby:
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Wow. Long delay between posts. As far as I can tell, the 91 - 94 Exploder has the same rad support so I'm back searching for a second gen 4.0 Ranger or 1st gen Exploder as a parts bucket. Mine is pretty well toast.
Not much point in patching that. See 4.0B2? Ocean! lmfao!
Should have the engine & tranny out of the Exploder today if all goes well. :icon_thumby:
4.0B2
151
Walls, MS
4.0 v6
I'll stick to my southern no rust rigs...
the only way we have rigs rust like that are either from the north (dang yankees) or rigs that people have flooded and left stuck in the pond for weeks at a time
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
The Exploder is nearly finished. Dropped the 2.9 and A4LD into it to reduce clutter around here. I hope this is the only 2nd gen Exploder I use for parts. Was not fun getting the driveline out. Oddly, the 2.9 went in pretty easily. lol
Saved the complete AC system cause it works. Just need the axle and springs, dash, wiring and column and its outta here. :icon_thumby:
Hopefully today. :)
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Just a quick update. Exploder is gone as of yesterday. Didn't take the column or dash. Project is on hold for a week or so. Woman wants me to work on the yard, Will add some B-II pix later. :icon_confused:
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Dude, awesome job on pulling engine, tranny and t case together. I would of never tried it.
Good luck on the project.
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Heh. I even left the exhaust on.
If I'd known what a PITA it was I would done it differently too. In the end I gained nothing pulling it all out at once anyway. I'm looking for a 5 speed parts truck if I can get one dirt cheap.
Thanks. :icon_thumby:
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
I gotta get the last of the inner fenders and rad support off this thing so I can hang the 4.0 in it. Be nicer to work on the front chassis and firewall then too.
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
I'm not sure this is the rear I wanna run. Seems like for every few people who love the 8.8 theres one who hates them. I might run it for a bit since I have it, but I'm probably going to go with a Dana 44 instead.
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Well, after like a week of yardwork, a little time to play with my Bronco II. So, of course I ripped it up some more. :)
Took the rusty tin off without really knowing when I'll be replacing it. For damn sure it ain't going back on. Have a line on a cheap ($300) '93 Exploder thats been badly beaten and laid on its side but its a day to get it here and probably another $150 cost. Mostly I'm thinking about it cause its a 5 speed. :icon_thumby:
