pressing wrist pins?
davecarr414
is it possible to remove and install pistons on the rods at home with a special tool or do i have to bring it to an engine shop?
pcollins
7
Middle of Nowhere, NY
GMC
4.8L
They just push out after removing the clips.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Some wrist pins don't just simply come out after a clip is removed. Some are pressed into the rod and that is how they are held in. This requires a press to free them from the rod. Can it be done at home....Yes. To reinstall the wrist pin into the rod you will need to heat the rod end up where the wrist pin passes through. Some even go as far as sticking the wrist pin in the freezer and the pins simply slides in. Then when both the rod and the wrist pins come to room temp they are set with each other.
davecarr414
yea there are no clips holding these together. ive tried to press the pin out of one of the junk rods with a vice but i diddent have any luck. this may give me a reason to buy a press.
Beef52751
13
Eastern Iowa
to get them out you need to put them in a press with light pressure on just the pin(make sure there is room for the pin to slide down) then, take a torch and heat the top of the rod and apply more pressure, when you get it hot enough you will hear a pop and the pin will start moving, once it starts going pump fast to get the pin to slide out.
it sounds tougher than it is but it is easier with two people. FYI this typically ruins pistons unless they are supported well
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
Yeahhh I broke one of my pistons trying to press rods on at home :dunno:
davecarr414
hmm i may give it a shot on one of my junk rod/piston assembliles to see if i can do it. im putting all new pistons on anyways so i could care less if i break the pistons removing them
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
it would have helped about 7 years ago.
What is with all these old threads getting dug up lately?
