If it even doubles my current OCI's, then it will have paid for itself within one or two oil changes. Not to mention it filters the oil to a much better state. Either way, its my perogative.
Okay, more parts to show....Im really starting a stock pile here, Id love some nice weather to get half of this stuff installed. Not to mention I have a 3 gauge A-pillar pod with pyro, boost, and water temp Isspro EV gauges on the way.
Figured since Id be toying with the cooling system, Id upgrade the thermostat and housing. The ford factory stamped housing is known to be crap, not seal, and rust out. So I got this housing from dieselsite, it is a machined billet thermostat housing bling bling! As wel from dieselsite is a 203* thermostat. It is made by International, and is a short stem unit that will not cut off the internal pump bypass, as the stock long stem units do. You may be wondering why Im bumping to a warmer thermostat, well long story short, International acutally designed these motors to run at about 203*, and up until 97, these are the thermostats that they had in them. The engines run better, and some guys have even seen an improvement in mpg. Either way I wanted to change it, and from my research this was the way to go.
I got one more thing in the mail, but it will be a bit of a surprise. There is a VERY common problem that all intercooled 7.3's are affected by, due to a stupid design. Hence I will use the following item and a bit of hardware to fix it........5 points to whoever guesses what Im going to use it for.
And....the Rangebe is getting its final part out this weekend, should be interesting. Anyone needs parts last minute let me know, will let them go for cheap, or for beer
