Questions about fuel Injectors
black_demon69
142
AZ
4.0l
If the 4.0l has 19lbs Injectors would it increase horse power to install 24lbs Injectors?
ericbphoto
Overlander in development
16,648
Wellford, SC
6"
I doubt it. The ECU fires an injector for a calculated period of time. With a bigger injector, at the same fuel pressure, the injector doesn't need to be open as long to give the proper amount of fuel. So the ECU is supposed to figure that out and adjust the "open time" usually called duty cycle. If the injector size is too far out of range, then the ECU won't be able to correct and your fuel ratios will be wrong. In other words, don't do it unless you understand all the ramifications and have tools and skill to retune it to work properly.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Ericbphoto is correct.
Increasing injector size without tuning will likely make your engine not run, or run like sh*t.
I run 24lb injectors on my 2.9, but I also have an aftermarket ECU. Injector changes for most tuning systems are 3-4 keystrokes. My ECU is set up to change the fuel map to match the volume of fuel my injectors can flow
If you do want a crisper throttle response, you can go to multiple hole injectors. May not do much for power, though. Then again, it may. Ymmv.
Looking for easy ways to get a little more oomph out of the 4.slow? (serious question, not sarcasm ??)
@ericbphoto: I really hate being "that guy", but injector opening time is pulsewidth. Duty cycle is a percentage of how much fuel an injector can flow. So at a given pulsewidth of X, an injector is at Y% of its duty cycle. Sorry if I'm coming off as a dick.
ericbphoto
16,648
Wellford, SC
6"
No problem. I know enough to give some advice and to know that I don't know it all. I have some friends in drag racing and I am learning a lot from them. But I haven't built an engine with stand-alone ECU yet. I have just enough knowledge to get started and to figure out what else I still need to learn. I may have gotten a term wrong. But I was in the ballpark with helping him figure out it's not "that easy".
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Don't kid yourself, you know a hell of a lot more than you think ??
Standalone ECU is crazy easy. If I can do it, anyone can.
black_demon69
142
AZ
4.0l
Thanks for the responses you all have confirmed what I was thinking. I am looking to replace Injectors because I have 3 that have gone bad somehow during the rebuild. (they worked fine prior to tear down)
Due to money will probably just replace the 3 and clean the 3 working ones. (I know they should be replaced all @ the same time)
Lance Morgan
99 RANGER WITH
FORD
I put v10 injecters in my stock 2.5 it helped it a lot low end and mid throttle responce
Lance Morgan
99 RANGER WITH
FORD
Iv addeded a turbo and intercooler and haven't programmed stock computer so my question is what are you guys using to rewrite maps and what are you using to program the computer cause I absolutely have to change the maps to get this girl to run right
Lance Morgan
99 RANGER WITH
FORD
Anybody know what size injecters are in a 460
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
24lb/hr.
Stuffing heavier fuel injectors in a stock engine is more less like the guy bolting a 750 double pumper on a stock 302, minus the flooding.
Now, if you up the amount of air coming in by a large margin (by forced induction, etc) then heavier injectors will help assuming the ECM is reading all that extra airflow
