Ranger '11 Rear Axle Swap to '04
Yspecv19
PA
First off, I'll say I'm new around here but very impressed with the amount of info. Also, I'm sure my question may have been asked before but couldnt find an exact answer to my question.
I recently found a '11 open 8.8" rear with 3.73 gears and disk brakes(obviously). My '04 rear is open with 4.10 gears and drums(obviously).
My main question is whether I will need to upgrade my brake master cylinder for the disk brakes? I could have swore I read somewhere that the stock master with the rear distribution block will work but I want to make sure. Also, just wanted to verify that the '11 axle is 3.25" diameter compared to 2.8" on my '04? Also, was just reading about gear ratios in the 4x4's. Will changing to 3.73 rear gears be compatible with my front end? What I just read was saying that it needs to be the same ratio.
Once again, sorry if this has already been asked but thanks for the info!
8,372
Welcome to TRS :)
4x4s must have the same axle ratios front and back
So if you have a 4.10 rear axle then front is 4.10 as well, if you change the rear to 3.73 then you must change the front to 3.73.
Are you sure rear is OPEN, 4x4s usually have L/S rear, not always but usually
Yes, the 2010/11 Ranger axle tubes are larger, info here: https://therangerstation.com/tech_library/Ford-8_8-axle.shtml
There is a Mustang disc brake conversion that you can use on your current axle, seen here: https://therangerstation.com/tech_library/ford_ranger_rear_disc_brake_conversion.shtml
Stock Master is fine for rear disc brakes
IMO, I would wait to find a 2010/11 4.10 rear axle, or do Mustang conversion on existing axle
You could also remove the 4.10 ring and pinion from current axle and swap it to 2010/11 axle, there is a learning curve to setup ring and pinion gears but its good to learn new things, right :)
Good page to bookmark here, loads of "been there, done that" info: https://therangerstation.com/tech_library/index.shtml
The above links are from this data base
Yspecv19
PA
RonD,
Thanks for the info. I'd though about swapping my gears in but for the price hes asking($300), I dont know if I wanna go through the hassle when i could just search around and find a axle with 4.10s. I have seen the mustang conversion before and have still considered that. And yes, it is an open diff as is my current one(code 97).
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
unless you get that 2011 axle REAL CHEAP it isn't worth it, in my opinion.
the axle shafts are only 28 splines, there is no provision for the abs/speed sensor, the brake mounting flanges are different.
for your viewing pleasure:
Yspecv19
PA
Thanks for the link. The seller is asking $300. I talked to him and told him I dont think it would be worth the time to swap the gears and everything just to get disk brakes. I told him much nicer though. I mentioned the mustang brake swap to him and he said he's got a buddy that works a lot with mustangs. He's going to see if he has any mounting brackets and parts. If not, I may just break down and buy the kit from Summit.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
if you're inclined to do some research try Crown Vics. the bearing, mounting flange & bolt pattern will need to match. maybe 98?
that would be for a disc conversion, not the entire rear end.
Junk Collector
Truck of Month
4,841
Rapid City SD
Easy way to get disc brakes is to install an Explorer rear axle, and they're easy to find with 4.10's too and usually limited slips. They're also cheap.
