Rear axle drone
Ericalan350
Houston, Tx
4.0L V6
I have a 1994 4.0 2WD (manuel trans) that recently between 55-65 mph I start hearing a drone sound as if there is a semi truck getting close to me. It gets a little bit louder up to 75-80 mph. It doesn't get better or worse as I decelerate or accelerate. I am in the process of changing the fluid in the diff between yesterday and today (it was time to change the fluid anyway). The internal diff looks fine. No excessive wear that I can see, no shavings or broken teeth. The truck has 275K on it. Has anyone ever had this issue that they can shed some light on where to look or a check list?
Also, does anyone know of a better way to refill the diff? I have a 5/16" clear tube and it is frustrating to say the least.
Thanks in advance for any helpful advice!
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
You can pick up a gear oil pump at pretty much any auto parts store for a few bucks, they just screw on the bottle of gear oil.
As for the noise, at 275k id be checking u-joints, pinion bearing, and wheel bearings.
Ericalan350
Houston, Tx
4.0L V6
The issue with refilling is the attempting to get the bottle close enough to the vertical fill hole on the pumpkin. With the gas tank in the way it makes for a tough angle to directly refill.
Regarding the noise, I replaced the U joints and the wheel bearings less than a year ago. I will put the pinion bearing on the check list though!
Thanks Dirtman,
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Do you have a limited slip rear? they can get noisy when they get worn as well.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,511
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
2 piece driveshaft? Carrier bearing could be suspect.
Something to think about.... might help you narrow it down. Driveshaft and wheel bearing noises tend to come in different frequencies. Depending on gear ratio... the driveshaft operates 3 or 4 times wheel speed. They just sound or feel different.
Ericalan350
Houston, Tx
4.0L V6
It is a 8.8 with a 3.08 gear. I will add carrier bearing along with the pinion bearing to the check list.
Thanks man
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
When I had a front pinion fail in my rear diff it sounded like someone had left a running turbo-shaft (helicopter engine) in my bed, it "whistles" at a steady cruise.
Will
514
Gnaw Bone, Indiana
Toyota
Good to see you around, AllanD!
