Reluctor Ring
Troy676
Canada
Afternoon:
Im in the progress of replacing my Open Diff with a Limited Slip Unit. Question is, do I need to Reuse the Reluctor Ring on the Carrier if there's NO ABS Sensors on the Axles. The Limited Slip Unit did not come with the Ring. I started the truck and the ABS Light does go off after its running. '96 Ford Ranger, Auto, 3.0 liter. 2 WD, use to be 1 wheel.....lol
Thanks for any Tips.
8,370
No, the ring is there only for the ABS sensor
You do have rear ABS on 1996 Ranger so ABS light will come on once you are driving if there is no rear sensor pulse
Troy676
Canada
So I need the Reluctor Ring?
Thanks
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
For ABS to work properly, yes, you need the ring.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If it came with the truck, it’s there for a reason. I would use it with the new carrier.
8,370
Thanks
If you have the sensor hole and sensor in the new rear axle, then you need the ring
