Rough and shaky idle
Kostlund
North Dakota
Ford ranger
hello Knute here new to the site, I have a 1983 ford ranger 2.3l 4spd, it’s been sitting for a looonng time, cleaned the fuel tank, carburetor, and fuel lines, and replaced plugs and wires, got it running, fixed some vacuum leaks now if just idles rough. Revs up just fine doesn’t die but not sure what’s cause the rough idle. Can some one point me in the right direction?? Thanks in advance
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
How was the carb rebuilt? You did it?
Float level correct?
Idle screws adjusted to get highest vacuum?
8,372
With air filter off and engine idling rough spray some gasoline into the top of carb
RPMs will go up some but what you are listening for is if the idle smooths out
If so you have a fuel delivery issue so carb issue, could be small vacuum leak leaning out mix at low RPMs or float bowl barely overflowing richening the mix at low demand
If its still rough then its a spark issue
These old distributors can have a wobble at lower RPMs that straightens out as RPMs go up
Feel the shaft for play
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,766
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
It might be time for a carburetor rebuild or a tune. Making sure the jets and ports are clean wouldn’t be a bad idea if you are going for the tune up first.
I would recommend listening to what RonD said.
