saggin coil
MUDDING B-3000
Barrie, Ontario, Canada
Ford , Ford
7.3L , 4L
ya my front right side of my truck is sagging down about 2 inches any ideas about how to fix that ? i was thinking new coil and shock? what are some good softer coils and shock my truck is very stiff and bounces around alot
Roadkill
Ontario, Canada
7.3l turbo
Well my first question would be what did you hit? Rangers typically lean to the left (drivers side) as that is where the fuel tank and driver are. Next, have you pulled the tire off to check the spring bucket at the top and the mount at the bottom? Is the spring broken somewhere?
A new shock won't do diddly for raising one side up at all. Softer springs will cause the truck to droop more. Remember you are driving a truck not a sports car, the suspensions are made to flex especially once they are lifted. The handling is completely different from cars/vans.
Jackson, New Jersey
sky jacker leveling springs and new shocks to match. They work wonders for you ride up front! do you still have the stock shocks?
MUDDING B-3000
Ford , Ford
7.3L , 4L
no it has skyjacker hydro7000 shocks and umm i think skyjacker coils not sure what one they had all that on it when i bought it, ya when i bought it, it had that lean to it. i was thinking it was jsut a weak coil? so it had that lean but im was sure
