Softer front end after TT?
Chris.S.
4
Kelowna, BC
After my 2" TT the front end of my truck is bit on the stiff side. I understand why that is but I'm wondering if anything can be done about it.
I should be able to find a softer shock I think? Maybe I need to change my torsion bars?
I know other people have the same issue, I'm wondering if anyone has been able to do anything about it.
Truck deets are in my sig below..
SAS is on the list but I've got a few years of warranty left before I really start hacking on this truck....
canyoncritter
6
San Diego
Willys,Ford,Jee
Its not that the truck has gotten stiff, it that the truck no longer has as much down travel.There for the truck will tend to skip over stuff rather than the suspenstion droping down
07rangersport
Maple Ridge, BC
4.6
with a 2" crank you have probably maxed them bars out. Of course they are gunna ride rough, they are at max preload. the only thing I can say is decrank them. My truck rides better after a mild crank.
Chris.S.
4
Kelowna, BC
Okay, so that helps to know that what I'm experiencing is a lack of downtravel...
Maybe I'm missing something here but shouldn't I be able to get a longer travel shock to compensate for that?
I hate this set-up.
Sunk
125
Everett, WA
3.5 Eco
Shocks won't help. The truck droops the little bit that it can then, you're up against your bumpstops (if it has them.) That's why it's so harsh.
Yellowsplash
11
Morgantown, WV
Yes....longer shocks will help. Need proof of this? Remove the top nut on the shock and jack the truck up. You'll notice that the shock (not sure if all aftermarket replacements are exactly the same length as stock) is too short for a 2" TT. You can add spacers to the stock studs (since they’re like 1.5-2" long anyway) to gain a little bit of downtravel if your on a budget, but this should only be used temporarily. Around a 1" longer shock should be sufficient. This will help it to ride somewhat better, but its still going to ride stiffer than a stock truck. As other said, if you have if cranked too far, the only thing that will help to alleviate the problem would be to use drop brackets to lower the lower control arms and longer steering knuckles to address upper control arm angles, and last but not least, torsion bar drop brackets....but your also looking at a pretty hefty price tag.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
You risk overextending the CV joints by running longer shocks.
racinranger
tuckerton NJ
when i talked to camburg they told me that ther 4x4 upgrade kit allows 1,0 inches more down travel with a 2'' max torsion crank on 98+ trucks. they sell it for like 600$ and give you 7100's shock mounts and straps. i know another guy did a homebrew setup with 7100's and neted 1/2'' extra travel. camburg said the cv's could tolerate 15* deflection angles. i measured my 08 fx4's and with them max cranked for about 2'' of lift im at 10*. i would measure your cv's and see what your deflection angle is before adding any longer shocks.
Chris.S.
4
Kelowna, BC
To measure the deflection is that just the defelction of stub vs axle? If I can dig an angle finder I'll check it tomorrow...
Yellowsplash
11
Morgantown, WV
Im running some spacers on the top of the shock studs on the sport trac. I did a 2" crank and it didnt have any downtravel. After adding the spacers, I rides better and the cv angles arnt at any extreme angles. Theres your first hand experience. But to each their own...
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
What angle are your CV shafts at reletive to your outer stubs? Do you have any pictures? I'm not doubting you, I just want to see proof.
racinranger
tuckerton NJ
i plan on fully testing this 15* angle camburg says is the magic number. im going to jack my truck up and strap it at 15* dead even so i maximize my suspension. im barely hitting 12* right now so i should be good for another inch by my calculating. i can get pictures with the angle finder
badbronc92
Colorad Springs, CO
4.0L SOHC V6
how much are spacers and who makes a longer shock? Most of them (Rancho/Bil's/ProComps) Say for 0" of lift only.How are you measuring the CV angles?
Yellowsplash
11
Morgantown, WV
You must have misunderstood me...nobody MAKES spacers. I removed the washer/bushing from the top of the shock stud and simply took a large nut (say 1/2") with a washer on top of it, then reinstalled the washer/bushing set. This basically gave me almost 1" of extra travel.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,862
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
Crapload of money for not a lot of lift. JMHO.
Just do a 1.5" crank and add a body lift for $300 if you want more.
With an IFS you're limited by the geometry to how much you can lift.
Even the 4" Superlift kit, all it really does is lower the entire front suspension and doesn't increase travel much if at all.
