SOLVED: 4.0 Radiator swap...is this the one I need?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
They make a 160 thermostat. What do ya think? This is a wheeling rig so I wonder if this might be a better bet. Gonna see a lot strain
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
160 thermostat will put your ECM into warm up mode, and make it run pig rich.
Look up a robertshaw flowkooler, or any high flow that will fit. Also look for one that fails "open" and not "closed."
If you're turning it into an off-road rig, maybe look into bed mounted radiators with e fans. Keeps them away from damage, much more efficient, gets the mechanical fan off the engine, and keeps slop out of the fins. There's really no disadvantage to them off road. The only reason to keep it in the core support is free cooling at highway speeds.
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
×2
A colder t-stat is likely to affect your MPG, as well as increasing cylinder wall wear.
Overheating generally means there are problems with the cooling system (dirty or clogged radiator, deposits in the system, weak coolant, etc.).
The way to avoid overheating (in addition to installing the bigger radiator) is to simply maintain your cooling system (replace the coolant every 2-3 years). The temps you mentioned earlier seem within normal to me also.
I run a 195° t-stat in mine and the 4.0L rad. Never once have had any heat issues, even here in the hot So-Cal desert.
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The thermostat temp rating is for when it opens, not what temp the engine runs at. If the cooling system isn't working, a colder thermostat isn't going to help. It may delay the overheating slightly, but it will still overheat.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
After playing around a bit, I don't like the temps. Rises to 210 way too easy. Gonna swap out the aftermarket gauge first just in case it's that.
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I had an impeller come completely off the shaft. It would spin enough at low rpm to keep temp down but with load would overheat.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
Any good way to test the pump before loading the parts cannon? I know to look for leaks, but other than that.
A thought just occurred to me. The belts are shitty. That could be the issue, right?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
OK, so high temps are not an issue as of right now. I changed the belts and that helped a little, but I still had a climb over 205 that I didn't like. I decided to see if there was any air left in the system. I parked the truck on a slight uphill incline. I let it run with the radiator cap off and a piece of cardboard stuck behind the spring of the throttle cable (to get it to 2500 RPMs). I let it run for a good 20 minutes like that. I didn't need to add much coolant at all, but I did notice the coolant looked a little rusty after the t-stat turned on the third or fourth time (it was not oil). I know the heater core was clogged up bad when I bought the truck. I remember the rusty gunk that came out when I flushed it - I am thinking I should replace that anyhow.
After that, I drove the truck in 4-low up and down some decent size hills for about 30min. I also got it up to speed in 2-high. Never went above 200. So problem solved, at least for today. I am thinking there was some air in there, or some blockage finally broke loose.
