SOLVED: Code 41 O2 sensor issue.
A4LD_Nghtme
54
Twin Bridges, CA
Bronco II XLT 4
Hey there.
I just started getting a check engine light and the only code I'm pulling is code 41. This is a newer o2 sensor and I have a replacement but was wondering what else could be the issue. I bench tested the grey and black wires and received rising and lowering voltage when using a torch on the end which I assume means those wires are good but I can't be to sure as I read 41 mean 3 things, 41 R HEGO (HO2S) sensor voltage low / system lean
41 C HEGO (HO2S) sensor signal out of range / always lean
41 C No HO2S switching detected
Any ideas how to fix this up right?
rusty ol ranger
2.9 Mafia-Don
7,692
Michigan
177 CID
Lean reading on the O2 could possibly be not the O2 itself...a vaccum leak, exhaust leak (before O2) can trick the O2 into thinking its lean.
Hows it running?
A4LD_Nghtme
54
Twin Bridges, CA
Bronco II XLT 4
Hows it running?
It seems bogged down like it's lost some power otherwise everything seems in order.
rusty ol ranger
2.9 Mafia-Don
7,692
Michigan
177 CID
A4LD_Nghtme
54
Twin Bridges, CA
Bronco II XLT 4
Start looking for vaccum leaks
Everything is connected. Where should I test and how? I don't have much brake cleaner to test. I can replace the o2 sensor and disconnect and reconnect all fittings
rusty ol ranger
2.9 Mafia-Don
7,692
Michigan
177 CID
Use starting fluid and spray around espicially where the upper intake bolts to the lower. While its idleing and listen for idle changes
I wouldnt mess with the O2 anymore untill you check for vacuum leakes
A4LD_Nghtme
54
Twin Bridges, CA
Bronco II XLT 4
Alright I sprayed fluid at the throttle body, the three lines under the throttle body, the vac line to air filter and the cap, the intake manifold, injectors, and the 4 lines that lead to the brake booster/climate res/fpr and I did not notice a difference in idle or engine sound. Still getting KOER 41
rusty ol ranger
2.9 Mafia-Don
7,692
Michigan
177 CID
8,374
41 (R) System lean
Is the engine pinging/knocking when accelerating?
And/Or overheating
These mean its "actually" running Lean
Lean codes don't usually mean the engine is actually running Lean, they are set when computer's OPEN TIME calculations for injectors are not long enough.......according to O2 feedback
So computer is opening injectors longer to compensate, and it reports this as Code 41
O2s only "see" the oxygen that's in the exhaust, there is a narrow range of oxygen content, the computer adds more or less fuel(longer and shorter injector open times) to try and keep the O2 in that range
O2s use 0.1volt to 0.9volt range
0.1v is high oxygen(Lean)
0.9v is low oxygen(Rich)
Computer tries to keep O2 voltage at 0.4v
So "low O2 voltage" = Lean, 41 can be defined as low O2 voltage or just Lean, same thing
Yes, vacuum leak means Unreported air is coming in that computer doesn't know about, so it has to add more fuel than it calculated, so longer open time for injectors and Lean code
Low fuel pressure
There is no fuel pressure sensor, computer bases its Open Time calculations on 35psi and each injector
If there is only 20psi, then computer has to open injectors longer, so Lean code
Misfires
When a cylinder fires it burns up fuel AND Oxygen
When it misfires no oxygen is burn and its dumper in to exhaust where O2 sees that extra oxygen............
Exhaust manifold leak
Exhaust leaks also SUCK IN air, O2s would see that extra oxygen, so Lean
But leak has to be between engine and O2, muffler leaks wouldn't do that, lol
Exhaust leak or misfires would also cause MPG to go into the toilet because they are "false" leans
Adding more fuel because there is a vacuum leak or low fuel pressure wouldn't change MPG
A4LD_Nghtme
54
Twin Bridges, CA
Bronco II XLT 4
41 (R) System lean
And/Or overheating
Low fuel pressure
Misfires
I'll pull spark wires tomorrow to check for misfire, I'll test fuel pressure, check fpr vac line for fuel, clean my maf and air filter, I'll recheck timing, recheck for vaccum leaks, possibly pull sparks to check for fowling and possibly pull injectors to see if they are clogged even though i installed new accels over a year ago.
Is there anything else I should check/perform to avoid taking this thing to a shop? I've heard 41 can be a real hair puller
8,374
You will feel a misfire if its bad enough to set a Lean code
FPR leak in diaphragm(vacuum) would cause Rich code, sucks raw fuel into intake, but test its vacuum hose
Check spark plug tips for darker color, that would mean a False Lean, engine is running Richer than it should
Test PCV valve, its a "controlled" vacuum leak, when they get oily they can stick open at idle, should be mostly closed
Also test Power Brake booster, hose, and then booster
Booster test, shut off engine, press brake pedal down 3 times, 4th time it should get hard to push
Then start engine, shut it off, wait 5min and do the same test
Booster should hold vacuum for a day to a month
A leaking booster is like a vacuum leak, because it is, lol
A clogged exhaust can cause Lean code as well but you would have more symptoms like slow REVing and lack of power at highway speeds
r-hindl71
Papa R
20
Omaha, Nebraska
Ford Ranger XLT
235/75R15
While I was working as a Ford tech I offended found where the rubber elbow for the vacumn line to the pcv was brittle and had a hole in it You might to check there closely, that was the most common problem I found
rusty ol ranger
2.9 Mafia-Don
7,692
Michigan
177 CID
I would check for voltage down to the O2 sensor.
The no switching detected kinda seems like maybe the ECM isnt getting the signal...IE broken/bad wire.
Might even be the O2 itself.
A4LD_Nghtme
54
Twin Bridges, CA
Bronco II XLT 4
Alright so far I've cleaned the MAF, cleaned the air filter, checked for misfire, replaced power brake booster grommet and check valve, clamped a loose line to the speed control servo, regasketed the MAF housing cause the gasket was falling apart, checked torque on o2 sensor, checked torque on intake manifold and undid the jet 66110 monitor that installed just before getting CEL. Still no improvement. It runs great at first but then like to start stuttering at idle and loses power. Should I just take this thing to aamco
8,374
Pull the computer and open it up
Look for any corrosion, computer board is coated with a clear resin, on both sides, so should be clean
There will be some radial capacitors, 2 to 4, they look like a barrel standing on end, these do blow out, top will not be flat but bowed, or they will leak at the bottom
Easy to see
Easy to replace these, under $1 each
Have a look at the 60-wire connector pins and slots, for corrosion
Sometimes just unplugging and plugging back in ANY connector will clean its contacts
