A4LD_Nghtme
- Nov 7, 2021
- 54
- Twin Bridges, CA
- Bronco II XLT 4
Hey there.
I just started getting a check engine light and the only code I'm pulling is code 41. This is a newer o2 sensor and I have a replacement but was wondering what else could be the issue. I bench tested the grey and black wires and received rising and lowering voltage when using a torch on the end which I assume means those wires are good but I can't be to sure as I read 41 mean 3 things, 41 R HEGO (HO2S) sensor voltage low / system lean
41 C HEGO (HO2S) sensor signal out of range / always lean
41 C No HO2S switching detected
Any ideas how to fix this up right?
