Spring Hanger Replacment
Kroeter
Ohio
V6 4.0
Is it possible to replace the front, driver side spring hanger without taking the bed off or moving the fuel tank??
I know I'm looking for the easy way out, but it's worth shot if it's possible!!
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I've done it. Its a pain to get the bolts in behind the frame but it is possible.
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
its stupid easy to pull the bed and fuel tank, not sure why you wouldnt do it.....
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Well for me...because its much faster not to do any of that when you have it up on a hoist.
Kroeter
Ohio
V6 4.0
Thanks
I'm working on it solo, so I was hoping not to have to take the others off.
Sasquatch-Ryda,
any advice in getting the bolts behind the frame? I'm assuming you are talking the tight fit between frame and fuel tank??
Thanks again
F8LBITE
Up North
3.0L
Have you inspected your other hangers? They might not be that far behind for replacement.
Kroeter
Ohio
V6 4.0
Had the rears replaced last year, had it done at a Spring Shop.
The broken one is the front, driver side. I'm sure the other front is not far behind and figure I might as well do it at the same time.
I just don't want to take the bed or tank off if at all possible and was hoping to do it myself!
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
When I did mine a couple years ago, I tried very hard to not have to remove the gas tank. But...it didn't work...couldn't get into where I need to get the bolts in place. I wound up supporting the gas tank on a jack, and just moving it out of the way a little bit in order to get at the front drivers side hanger. Good Luck!
Kroeter
Ohio
V6 4.0
YYC
Thanks. I've heard you can move the tank enough, so I'm going to give it a shot. I'm sure my 7 and 4 year old will hear some new four-lettered words.
Thanks and we'll seehow it goes!!
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
Put that 7 year old's skinny little arms to work!!! He/she might be able reach enough in there to put a bolt in place...tell you wife you're bonding by working in the garage :icon_thumby:
Kroeter
Ohio
V6 4.0
YYC,
That is a great plan!! I will give it a try, my 7 year old is planning on taking this Ranger to his prom with Historical Plates on it!!!
Thanks!!!
