steering column interchange
mnmattie
when doing the 89-94 dash swap into the 84-88 rangers, can you use the explorer steering column or are they different than the rangers???
pillen140
45
winston-salem, NC
cant you use your original column? idk, but i thought the only difference was the steering wheel... i may be wrong though
mnmattie
Well Im switching over to auto so I had planned on using the explorer column, but it isn't fitting as I thought it would. Maybe I do need a ranger column???
I had to move the mounting bracker on the column up since the whole column seems to be a hair longer than the ranger column. And there's no room to connect the ignition switch pigtail in either, so might have to make a trip to the local yard and see what i come up with.
mnmattie
figured it out. i had to remove the steering shaft from the column to the gear box, install the column and then reinstall the shaft. works now.
Bobber64
49
Brooklyn Park, MN
Old thread but I’ll give it a try. I have a 85 ranger, I’m doing a 302 automatic swap. I would like a tilt automatic shifter column with cruise. Does anyone know what columns will work? What year Bronco II’s Rangers?
