Well Im switching over to auto so I had planned on using the explorer column, but it isn't fitting as I thought it would. Maybe I do need a ranger column???
I had to move the mounting bracker on the column up since the whole column seems to be a hair longer than the ranger column. And there's no room to connect the ignition switch pigtail in either, so might have to make a trip to the local yard and see what i come up with.
Old thread but I’ll give it a try. I have a 85 ranger, I’m doing a 302 automatic swap. I would like a tilt automatic shifter column with cruise. Does anyone know what columns will work? What year Bronco II’s Rangers?
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
