steering while in 4 wheel
TheDanger2801
Orono, ME/Yardley, PA
went into 4 wheel last night and worked fine untill i made a U turn. as soon as i cut the wheel either direction the truck wanted to stop. when you give it gas it almost seems like it drags the back end. then when you even the wheel out it drives like a truck should in 4 wheel. it feels like steering binding when you go past a certain point in turning the wheel. i have a 98' ext cab with electronic 4x4. can anyone help me. Im afraid to bring it to the dealer in fear of cost.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
this is normal.
think about why you have a differential in your axle. it is so that when your are turning, the inside tire and the outside tire can turn at different speeds because each is traveling a different "circle".
the same thing happens with the front of the vehicle and the back of the vehicle. the front makes a bigger circle than the back. because there is no differential between the two axles, they are forced to turn at the same speed and the tires end up slipping/scrubbing.
all wheel drive vehicles have a differential between the front and rear. 4x4 vehicles dont because the 4wd function is not meant to be used all the time. especially not on dry pavement.
hope this helps take care of your fears.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
What he said.... Except for one thing
The reason it was binding was because you were on a surface with too high of traction, meaning at the time you were turning the road or surface was not slick enough to need 4WD. Your truck will do this anytime your in 4WD on a high traction surface.
It can actually damage your truck if you do it too much, so I would make sure it is slippery enough to use 4WD, or not make such sharp turns when your using it.
TheDanger2801
thank you very much. the only reason i though it was strange was because when i used 4 wheel many times before it never happened maybe thats because it was off road. never thought of it being dry pavement. thanks again.
