TBI to carbed 302
MaGiKaLsHoTs
Wilmington, VT
(01) / [94] / {
[3.0L] | (4.0L) | {5.0L, sas 35 boggers}
is it possibly to go from a TBI to carbed? i looked at my block and the intake looks the same as the one i picked up off my old carbed block.... all in all it looks like all i gotta do is take a carb and throw it on?
martin
26
St Bruno, Quebec
1991
If it has a tfi distributor you will have to do something about that or you will have no ignition advance.
martin
26
St Bruno, Quebec
1991
The duraspark distributor with the gm module is the easiest route. Less wires and great performance
fordmike1
Back in Queen Creek, AZ
1994 & 1983
5.0l
First thing is, Is your 302 a roller engine or not? If its a roller you need to use a distributor with a steel gear and if its a flat tappet cam you will need to use a dizzy with a cast gear. For a roller cam use the dizzy for a 85 Mustang GT with a Holley 4 barrel carb and for a flat tappet cam use one for a 84 Mustang GT. The easy way to wire it up with the least connections is to find a stock Ford duraspark box and harness as you will only to make two connections and the reast is just plug and play. There is no advantage to using a GM module and it is more a pain to use anyways. You will need to make a heatsink for it and mount it some where and then make up your own wires and if it dies then you are stuck unless you have tools to replace it right there. The Ford Duraspark is a much better deal as if it dies you just unplug the dead one and plug in a good one and go untill you find some tools to do it right. The other big advantage is the Ford duraspark box retards the timing while you are cranking the engine to make it start easier and it also saves the starter doing that. More pluses to the Ford stuff then the GM junk.....
bobbywalter
Ugly Truck of Month
4,684
woodhaven mi
FORD mostly
BIGGER
sawzall?
if it is a stock tbi, its not roller...and likely a 255 and not a 302. if it says 4.2 under the hood of the donor you know its likely a 255.
a 2150 and a d spark for an 82 will work if its stock but you may want to open it up a bit.
MaGiKaLsHoTs
Wilmington, VT
(01) / [94] / {
its a stock tbi and its def a 302.. i looked up the block code and i beleive it said it came from like a 80's mustang
BlackBII
Ranger Custom
Truck of Month
984
UT
I didn't think there was ever a TBI 302 in a mustang?
In 86 they switched from a carb to multiport injection.
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Mustangs had TBI in '84/'85, somewhere around there, It was only automatic cars, maybe just convertible... Google would provide some info.
This is why when a Duraspark distributor is recommended for use with a roller cam, only the 1985 5speed Mustang 5.0 is the source.
baddad457
18
Opelousas La.
There was only one specific block code for a Mustang 302. And that was the 69-70 Boss 302. All others had the same casting numbers everything else used.
bobbywalter
Ugly Truck of Month
4,684
woodhaven mi
FORD mostly
BIGGER
sawzall?
if it was from a 83 or newer stang its def a 302 and the best of the cfi engines. those were over 150 hp....so i guess its ok anyway for the time period..
i assumed he has an eec4 cfi, and not the eec3
superdave1984
24
KY
Isn't this the same exact problem? Unless you have a replacement you are stuck no matter which you use.
85_Ranger4x4
18,004
SW Iowa
A JY DS module is cheap to test and throw behind the seat just in case. No tools required to make it go, and only a single wrench to change it.
Heck, I pulled and OEM Motorcraft one out of a JY in '04, kept it in my tool box until I durasparked my 2.8 in '07, and it still works fine.
Never been around HEI, but I haven't had a problem with DS yet to make me change.
MaGiKaLsHoTs
Wilmington, VT
(01) / [94] / {
ok i will post the block code later today.. im going down to work on it and ill look over it again... the guy i bought the motor off said it was a 302 out of either a mustang or crown vic or somthing like that.. around early 80's.. ill look again and post the block code
85_Ranger4x4
18,004
SW Iowa
The engineering code of mine that came out of a Crown Vic
E = 1980's
7 = 7th year of 1980's (1987)
T = Truck
E = Engine part
The 7 is the model year the thing was designed for, but like E7TE cylinder heads came out in '87 but were used well into the 90's... it isn't a for sure way to id something. They ran with that number until they changed something.
So don't plan on really nailing down what it is out of that way. You can get a hint of the year with it, maybe the make (Lincoln, Mercury...) the emissions sticker on the valve cover will tell you the year of emissions it met and what the displacement is. That is what to go by for what you actually have if it still has it. Variations in the front engine accessory drive might narrow it down too.
The engineering code thing is kind of a handy thing to catch onto, I could tell by the stickers on mine that it was later than the '84 it was advertised as. It even carried over to their tractor line too.
