TDI Ranger Build
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I would have kept the ranger condensor (plug in play to hvac box for ac lines) as well as the ranger rad and just adapted the vw e-fans to the rad, but that works too :icon_thumby:
SVT
greengeeker
Firefighter
9
Cambridge, MN
1.9L
Your way would have worked well but I have plans for the space occupied by the condenser and radiator. (see next post)
greengeeker
Firefighter
9
Cambridge, MN
1.9L
Intercooler Mounting
I mentioned earlier that I wanted to keep my radiator and intercooler tubing as simple as possible. Of course the simplest solution for a longitudinally-mounted TDI would mean both inlet and outlet of the intercooler be on the passenger side. It took a lot of looking but I found such an intercooler that fits between the Ranger frame rails. It is a little tight so I bought some cast 90's to replace the straight out inlet/outlet.
I trimmed the condenser bracketry a little and this guy simply slides in place! I'll probably trim the driver's side bracket a little more to shift it a little further towards the driver's side and gain clearance for the inlet/outlet.
kmdracer
Interesting to say the least. Subscribing to thread to tag along. Good luck with mods!
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Cool project. I don't know how far I'd trust that radiator support though.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I can't believe how many of these things have rotted radiator supports. Seems like the first thing to rot out anymore.
My F150 is pretty bad, I'm gearing up to replace it soon (before winter).
snoranger
Professional money waster
ASE Certified Tech
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You are correct sir. I'm going to box in my brackets as they were flexing almost as much as the rubber mounts.
I think he was referring to the rust. The rad support rusts from the inside out and once they start, they go fast. I've seen a lot of them that the entire bottom section is just gone.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
You are indeed correct. I'd replace that thing now while it's torn down that far.
snoranger
ASE Certified Tech
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
IAmTodd
Johnstown, PA
I'm looking forward to the outcome. I think a diesel is in my Explorer's future.
Rose2300
7
ID
Toyota
3.4
sub'd. my parents just bought an 02 jetta tdi w/70k on it and it has a suprising amount of pickup for how low the power rating is. i love the acceleration on the freeway with out having to downshift!
b411sac
U.S. Military - Active
Ft. Drum, NY
Any updates?
Sent from my ADR6425LVW using Tapatalk 2
