Towing with a 4.0 manual
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
Once the clutch is engaged, your flywheel might as well be bolted to the transmission. The clutch only matters when it is slipping.
FYI, BDAB, there is a risk to your approach. The engine won't lubricate properly at idle speed at full throttle. I'd say there is a happy medium somewhere. You have to balance engine risk against clutch risk. I agree that you should get off the clutch as fast as possible, but I think that's a bit too fast. Note that you have the same issue with an automatic transmission -- the fluid will burn up if you "slip" the torque converter excessively under heavy load.
I never said anything about WOT......... but my foot is no where near the gas pedal when I let the clutch out.
Wicked_Sludge
43
Westport, WA
3-point-GO
However on the freeway or anytime the clutch is fully engaged can towing heavy loads effect the life of my clutch?
the short answer is: NO. when the clutch is up (fully engaged) there is no movement of the clutch disk in relation to the pressure plate and flywheel. a clutch does not wear AT ALL when it is fully engaged, regardless of how much weight its moving.
motoxchamp
thanks I am onky mechanically enclined with motorcycle engines so I've been applying some of the principles of a mx engine to a truck but alot of stuff doesn't work even remotely similar
Ozwynn
200
Berrien Springs, MI
RE Interceptor
there should be no slippage..... if everything is working properly.
