- Aug 31, 2021
- Reaction score
- 974
- Location
- Roanoke VA
- 1997 and 1999
- Make / Model
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- Automatic
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
I'm having a hard time finding 265/75R15 tires (oem size) in a somewhat aggressive tread. I know I can go 31" and be ok, there may be some minor rub issues. 265's should have zero issues of that kind.
Coopers might be ok for me but I'm pretty sure I want a bit more aggressive, but not a mud tire. The only thing I find in 265 is this: Toyo Open Country A/T III | P265/75R15 (tirerack.com)
They have the sidewall tread I want, don't like the white lettering but I think you could mount that inside. What I'm asking is if anyone has experience with the Toyo. Or if you know any 265's that are similar. I can't find K02, K03, Grabbers, etc in that size. I might be wrong, but seems like narrower tread (compared to 31") is actually better traction because more psi since less surface. It might be insignificant as far as performance (in rain, dirt, minor mud, etc). Noise is somewhat of an issue but I'll sacrifice some roadability for better off road performance.
Not saying I won't go 33" at some point but it probably won't happen before I have to get new tires because the 235's on there are starting to get marginal for the tread wear.
Also would appreciate any comments about bead balancing vs normal weights. I understand lead weights can react with the aluminum but there are coated ones or other metals, so I'm led to believe.
Date code on them is something I'd check too.
But if Toyos aren't so good and that's my only choice in 265 then I'd probably go 31" because likely they will be newer-made and there's much more selection.
Thanks.
Thanks.
