TPS problem?
bmxjunkie
Germantown, MD
Ok, i have a '98 B3000, and have recently run into trouble. It wont run, and when it does, it idles really ruff, than smooths out, than ruff, than smooth, and so on. when i press the gas (even when in neutral) it lugs and usually stalls.
I thought maybe ice in the gas lines, because there's snow and ice everywhere and ive been drifting and such, but i put fuel line antifreeze in it yesterday when the problem arrived, and it hasnt changed yet.
Next best guess is the TPS, because its just acting like it isnt getting any gas, but im lookin to see if anyone else has had this problem, and maybe knows what to do. anyone?
thanks for any help given
KELLY88
4
Lake Mary/Daytona Beach, FL
4.0, 4.0
Could be a number of things. Are you getting any check engine lights?
Earl43P
38
Farmington, Pa
Ford F250 4WD
Prime the fuel system several times before cranking (key to Run, pause, hear FP run then stop, key to OFF, repeat, repeat, repeat then crank the starter).
If Fuel Pump isn't audible, check inertia on PS where their toes hit, pull the carpet back, push reset. Still no FP, check fuse. You can also press the schraeder valve on the fuel injector rail. Remove cap, find tire-stem-like valve, use a rag and press center expecting great spray. Or attach a Fuel Pressure guage.
It's a start.
Welcome to the Ranger Station.
bmxjunkie
Germantown, MD
nope, no check engine lights.
and thanks earl, i give that a try
kossdust
Mazda
Check your spark plug wires make sure they are all connected good and tight. Could be something loose
Have you done anything before this started? Or is it just out of the blue?
bmxjunkie
Germantown, MD
I'm pretty sure they are, but ill double check. And its pretty out of the blue, it started acting up on tuesday, than finally died a few hours later.
The truck does run....kinda haha. When i try and start it enough times itll finally idle ruff and smooth back and forth,than finally start to run smooth like normal, but when i open the throttle it starts to lug and die..
Current diagnosis is fuel pressure regulator is stuck open. They're cheap, so I'm just gonna buy one tomorrow and slap it on.
But if anyone has any other ideas lemme know, im open for any answers.
bergz0
9
nj
leveling kit
31x10.50x15
mine did the same awhile ago, i threw a tps sensor on it, idle control valve and a maf sensor. fix that problem right up. hope this helps :)
Hardwareman
SoCal
Does it smoke at all?
Allen
bmxjunkie
Germantown, MD
FIXED! it was a MAF sensor. went to crazy rays junk yard, pulled a new one off a ranger, not my truck runs like a charm.
thanks for all the help guys!
