jcook100
- Apr 5, 2019
- 10
- Salt Lake City, UT
- Ford Ranger
1991 Ford Ranger 4.0 RWD
Main problem: I have a hard time shifting from 1st to 2nd, and sometimes into 1st. There is no grinding, I just have to push/yank the gearshift to get it in gear. I changed the transmission fluid, but realized that there is a broken seal/gasket where the driveshaft connects to the transmission (see picture). There is transmission fluid leaking at this seal (I think) and dripping from the bottom of the transmission housing. Changing the fluid may have helped a little, but the problem persists.
I also tried to pull out the clutch master cylinder and lines to check and bleed them, but ran into two additional issues. First, I could not remove the line connecting to the slave cylinder. I have watched the videos on this but still couldn't get it to release. Does the special tool make a big difference? I was just trying with a screwdriver, pliers, etc. And I don't need to remove the clamp from the female end, correct? Second, I noticed that my clutch pedal does not include a clutch interlock switch and the rod doesn't seem to really be "connected" to the cylinder - just basically sitting limply inside of it. Is it possible that someone remove the interlock switch before I purchased the truck? Do I need to get one?
So I am not sure how to approach these issues. Is it possible that bleeding the clutch will resolve the main issue? Or maybe replacing the slave cylinder? Or does it sound like a full rebuild is needed?
How should I prioritize my next steps? Thanks!
