- Sep 21, 2007
- 671
- Wa, Bremerton 98310
- Ford
- Engine Size
- 87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
- 2WD / 4WD
- 4WD
- Total Lift
- Ranger 5" (1½" suspension), BII 4" suspension
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 33"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
Kehworth,
I would remove the lower set of blocks and rebuild the rear spring packs with a set of Explorer packs, making it the height you want.
The front is different, definitely get new springs but your setup is stock so anything with more lift is going to run your tires bald on the outsides. Without adding a lift kit I would get stock replacement or the heavy duty version of the same. The phone James Duff LLC and they will let you know what information they need to select the proper size 70/30 shocks for you.
