What would you do?
86MUDRCJ
8
Sheridan, CA
Okay guys, I've been thinking for awhile about what I'm gonna do as far as motor options for the truck. I know ultimately it comes down to budget, but with the new job ill have a nice chunk of change to throw at it every month. So here's where I'm at:
1) Put a used 2.9 back in without rebuilding just to get it back up and running. Or rebuild a motor from the junkyard.
2) Put a 4.0 in there for a little more power.(but I've been told the fuel economy isn't great. I've even been told its llike having v6 power with v8 mileage.
3) Just go crazy and put a small block in it. Obviously this would be awesome but I don't really know if I want to do that because I haven't v8 swapped a ranger before.
So I guess what I'm asking is, if you were in my position what would you go with, and just a brief explanation why would be great. Thanks in advance!:icon_thumby:
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Option 2. You got it backwards. Its v8 power with v6 economy. I got 22 mpg in my B2 with sensible tires on it.
I love my 4.0. would not trade it for a v8
straycat
77
02 06 and 2012
Jeeps
If money is tight I would just put the same motor back in. If you can have yours rebuilt...do it. If you can find a really great running 2.9 that has no issues then buy that and just swap it out on the weekend. A 4.0 will involve a trans swap as well and a harness swap too.
86MUDRCJ
8
Sheridan, CA
What do you mean by sensible? I'm planning on 35's but I'm going to be gearing too.
Right now momey is kinda tight, but if need be I can just put a little away at a time. I see quite a few trucks around here that have the 2.9 but usually the headgasket is blown or something else. My grandpa knows a guy that owns a pick n pull and when he buys a complete motor there the guy warranties the motor himself. Maybe I could go that route?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Sensible tires were 225/75/15's that I got cheap.
I'm runnin 30's now with 3.73's and will get 17-18 highway with out any adjustment to the speedo for tire size.
I also drive it like I stole it because it runs great. The 4.0 is a fun motor. It used the same motor mounts, I'm using my 2.9 M5OD. It's just fun to drive, and it has a 4 " lift.
No regrets on the 4.0.
85_Ranger4x4
18,003
SW Iowa
The 2.9/4.0 would be the easiest/cheapest. I personally don't deem either worthy of rebuild vs chuck and replace.
My mother's 4.0 Explorers (94 4.0 ohv 96-10, 02 SOHC 05-current) with stock tires and gearing have struggled to approach upper teens on the highway... the '02 is better but it is about on par with my 5.4 F-150 that has 32" mud tires.
A SB swap is a ton of fun to drive but it is a serious investment of both time and money. Don't even consider it if you don't plan on keeping the truck for a long time or don't have another good vehicle to depend on while you are putting it together.
With a 4bbl, three speed, 3.73 gears, 31" MT's I get about 10mpg at 60mph... which isn't too bad for a V8 turning 2700 rpm. My one regret is that 3 speed trans...
stegomon
20
auburn/minot maine
fords and only
i say 4.0. i will be working on my swap this winter:icon_bounceblue:
Road Angels
27
cold as hell
2.5L
Answers kind of a no brainer, no bucks equals whats cheapest get it running then collect what you want to do with it in the future when money isnt a problem
86MUDRCJ
8
Sheridan, CA
Holy cow! A 3 speed would seem like it would sick the mileage down a bit. I do plan on keeping the truck forever honestly. My wife and I are sharing the ecobox right now, and that's why I've been able to sort of put money away.
The only drawback for me is, a lot of people swap in 4.0 and with the tire size I'm running, I think I would have to gear the axles down quite a bit.
True, but the motor is alreadt out of the truck. All I would need to do would be drop the tranny and driveline and I'm ready to start swapping stuff over.
70roadrunner
8
sedro-woolley, Wa
1970
194
plymouth
2.8
If you need it as a daily driver, I recommend the 4.0 swap. its a little more work, but well worth the effort. and you wont wish you had done that at a later date. ive done swaps before and then wished I had gone a different route, but it was either time or money that dictated what I was able to do.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
I met a guy running 35's on a D30 in a Jeep cherokee with 3.55 gears.
It can be done, not saying you'll have a lot of power, but you can run em
