Where are the vents on my rear axle assembly?
Paisano
136
Phoenix, AZ
Ford Ranger XLT
92' Ranger XLT with 2.9 V6 and push button 4WD. I just replaced a leaky rear axle wheel seal today.
I heard that clogged axle tube vents can cause the rear bearing seal to leak gear oil. I know of one pin hole vent on top of the axle tube.
I checked it today. Are there any more of these vents I need to check on my rear axle?
scotts90ranger
4,447
Dayton Oregon
2.3 Turbo
The only vent is on the drivers side axle tube, it's just a fitting that points up and is "supposed" to go to a hose that goes up and is clipped to the frame rail, that's it. On my F350 the 10.25 the fitting is the bolt deal that holds the brake line tee to the axle tube, turns out it was plugged and didn't have a hose (knew it didn't have a hose, but hadn't looked too deep until it lubricated the brakes...), fixed that and it's been fine, on the Ranger I put a piece of nylon hose on it and have it somewhere safe...
Paisano
136
Phoenix, AZ
Ford Ranger XLT
Yep. That's the one I checked Scott. Thanks Man!
You're right. Mine is on the driver side axle tube and there is a hose trailing to the frame rail. I just wanted to make sure there weren't other vent locations.
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Shouldn't there be like 3 vents total the diff's have them right?
Paisano
136
Phoenix, AZ
Ford Ranger XLT
I'm not sure now James. Scott says there is only 1 for my make/model.
But I'll email the manufacturer of my rebuilt axle assembly. They will know for sure.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Only one on the rear diff... one on the front diff.
pjtoledo
2,995
Toledo Ohio
Fords
3.0 2.3
and a stubby on the transfer case, at least on some transfer cases (disclaimer)
Uncle Gump
Token Old Guy
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Transmission too...
scotts90ranger
4,447
Dayton Oregon
2.3 Turbo
Yep, what they said, each axle only has one vent, it's a fixed volume that doesn't change temperature too much, it doesn't need flow and as long as the vehicle isn't upside down the vents should be out of the fluid level...
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
one on rear diff, one on front diff, one on transmission, maybe one on xfr case
it sounds like 4 vents to me
guess I'll have to take a good look under mine and see
I seem to go through a lot of water so it's a concern for me that they all be high enough to not suck in water
Paisano
136
Phoenix, AZ
Ford Ranger XLT
I already got a reply from the manufacturer of my rebuilt axle assembly.
I have the 8.8 with the 4.10 gear ratio. They said it only has the one vent on top of the driver side axle tube.
By the way, what is the standard procedure for filling a rear axle with gear oil? I know when you first drive it, some of the oil will get diverted to the axle tubes down to the wheel bearings. So then the level inside the pumpkin will go down some. After the initial fill, do you top it off maybe 2 more times?
James Morse
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
Was that a stock 4.10? I don't think you see tons of them?
Paisano
136
Phoenix, AZ
Ford Ranger XLT
It's remanufactured. So I'm sure it was rebuilt from stock.
( Hey James, I grew up in Richmond, Virginia)
Paisano
136
Phoenix, AZ
Ford Ranger XLT
The manufacturer said they would reimburse me for new brake shoes (contaminated from leaking gear oil), misc supplies, and the new seal under warranty. But he wasn't really open to compensating me for a new brake drum. He said it can be cleaned up and doesn't need to be replaced.
Is this correct?
Uncle Gump
Token Old Guy
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm sure you can just clean it up. Then clean it a little more.
Did you look at the axle shaft sealing surface? Was the vent not venting? Was the seal not installed correctly?
