Where to find OBD II codes?
dwsykes
Kinston, NC
3.5TT, 2.9
Where can I find a list of what the trouble codes mean for my truck? I have a scanner and it reads six codes P0171, P0174, P0000 X 4. I would love to have a printout of all the codes if possible. Thanks in advance.
dwsykes
Kinston, NC
3.5TT, 2.9
Thanks. I now know that Bank #1 and Bank #2 are too lean.....crap:icon_confused:
cr_the_machinist
Dexter, Michigan
4.0L OHV
Check for vacuum leaks and low fuel pressure.
3,615
Bank 1 and 2 lean is usually caused by one of two things. A) bad intake gaskets, but that usually sets a code for only 1 bank. B) vac leak.
The test is the same. Spray around the engine bay with a can of brake cleaner or carb cleaner and listen for it to rev. As you hear it rev up, go back over that spot until you figure out where the leak is.
Try not to use starter fluid, it makes it run too rich and doesn't burn off fast enough.
dwsykes
Kinston, NC
3.5TT, 2.9
Thanks guys, I will be sure to do that sometime tomorrow, or when....I get a chance. It has been one of those weeks and it has just begun! :sad:
3,615
I feel you man. 2 hours trying to get a Dodge ball joint out today. It still shows no signs of budging.
dwsykes
Kinston, NC
3.5TT, 2.9
That sucks....My brother's F250 ball joints were "challenging" but we found a little nudge with a LARGE hammer did the trick :icon_thumby: Good Luck!
dwsykes
Kinston, NC
3.5TT, 2.9
I found the leak! :yahoo: It was right under the throttle body to the left side. It looks like an elbow that leads to the backside of the engine.
3,615
PCV hose. Common leak spot on those trucks.
3,615
I used a little "nudge" from my shop foreman's big hammer while hitting it with the press.
dwsykes
Kinston, NC
3.5TT, 2.9
Glad to see you got it apart.:icon_thumby:
It is cracked on the underside, the carb cleaner found it right off. Now I just need to find a suitable replacement. Would it be best to go to Ford or to an auto parts store?
3,615
You can try the parts store, but it's a formed, elbowed hose if I recall correctly, so I'd recommend a direct fit replacement. So if the Parts store can't get it, I'd go to Ford. Might cost a bit more, but it's worth it to get the formed one.
dwsykes
Kinston, NC
3.5TT, 2.9
Thanks, did a bit of searching and came up with F8UZ-6762-AA for the part number. I searched the part and wow....it must be a common problem for me to get that many related results. I greatly appreciate all the help.:D
