Found! WTB: Ranger Rear Axle
Status
Not open for further replies.
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
looking for 2003-2007 FX4 Level 2 complete axle assembly
rusty ol ranger
2.9 Mafia-Don
7,510
Michigan
177 CID
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Was one here in the local u-pull, but it was fed to the crusher after 9 days. I found out when I went for the axle. Got the Explorer one instead. May want to look into it. They're a better axle.
rusty ol ranger
2.9 Mafia-Don
7,510
Michigan
177 CID
Didnt the level 2s run a 31 spline with a 4.56 gear?
smilinjack
34
rochester, mi
ford ranger
408C
2"
I believe the level 2’s ran a 4:10 ??
smilinjack
34
rochester, mi
ford ranger
408C
2"
I’m in the process of buying a FX4 level 2 from an 03 ranger. 31 spline, 4:10, w/ torsen locker ?
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
Good luck finding one of those in a junkyard. Its got the 8.8 31 spline rear end which is killer in a ranger. The explorer rear axle will give you calipers instead of drums but there's some welding involved if you are capable. Explorer will be more common than a level II.
RobertjeD
Jordan
Manzana Golden
With craftsmanship like that, I can see how Dan gave you permission to build a replica Looks really good so far. Are the joints tigged, brazed, or soldered?
NakedDucks
63
B’ham AL
You still looking for one?
smilinjack
34
rochester, mi
ford ranger
408C
2"
Not sure if you're answering my search from 10/19 but I did find one and installed it last year. It came from a junkyard in Canada off of a 2007 Level 2.
Had it totally rebuilt and powder coated and I welded a ladderbar kit to it with QA1 coil overs, 10" drums. It was a 4.10 posi w/torsen locker. 31 spline, 3 1/4" axle tube diameter. Nice piece, hard to find
Status
