Your budget is $10k for an Apocalypse Vehicle
ekrampitzjr
1,085
Virginia
You can carry more in a bike than on your back.
Airless tires would be nice. Not something I’ve seen for bike though.
Solid tires were once available for bicycles. I learned to ride a bike on an ancient men's bike my dad had gotten from somewhere that had solid tires. It probably dated from the 1930s. On paved residential roads solid tires don't make that much difference at typical bicycle speeds.
The problem would be when it finally is time to change the tire because of wear or cracks. Imagine taking a solid tire off a bicycle wheel using regular bicycle tire irons.
rusty ol ranger
2.9 Mafia-Don
7,643
Michigan
177 CID
Last bike tire i changed i did it with only my hands
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,755
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
BroncLander
412
BC Canada
XLS Bronco II
When I worked up at the mine they had a few bobcats there and they had airless tires. Solid rubber with lateral 3inch holes through the sidewalls. They lasted forever on sharp rocks all day
rusty ol ranger
2.9 Mafia-Don
7,643
Michigan
177 CID
Ive seen forklifts with those too.
Wonder what the holes are for though? To soften the ride a bit?
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Exactly.
ericbphoto
Overlander in development
16,730
Wellford, SC
3.0L
6"
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
They prototyped the hell out of those for Humvees. I tried and tried to get a set
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
That was over 20 years ago...
BroncLander
412
BC Canada
XLS Bronco II
I'm starting to think I really need to build an apocalyptic mad max truck.
I was thinking about it last night and if I started with 2 good axles from an F350, and a smaller truck frame, 4 tires, 4 leafspring packs, I would be at the rolling chassis stage. And I think I could do it with all used parts from either cheap rigs with blown engines or junkyard parts.
I think I could have a rolling chassis assembled for under 2k.
Even a frame from a Caddilac or something like that would be stout enough for a diesel engine or a big block. And if I run a divorced transfer case, I can swap in donor engine and trans combos anytime with relative ease
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
that is exactly my truck......wasnt kidding earlier...
i used to have runflat humvee wheels.....and likely will get them again.....it has a humvee engine....actually pieced together from 4 engines....cucv and hmmwv donors....only new headgaskets and bolts....few different injection pumps.....hacked together and modded injectors to run alt fuels....
dumb.....cheap......easy......reliable.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
They are effective......
Eric's as well....
your bronco is what you need .
Won't take much.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
4x4 junkie....look up his b2.
It's all a guy needs to escape. Be easy for your rig.​
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
