Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Non-Ranger Axles
Notices
Non-Ranger Axles All other axles. Ford 9-inch, Dana 44, Dana 60, etc.
Reply
Thread Tools Display Modes
Old 12-12-2017, 10:50 AM   #11
evanesce69
evanesce69's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger 4x4 Super Cab
I use this vehicle for: Daily Driver
evanesce69 is on a distinguished road
Send a message via Yahoo to evanesce69
Default
There are, but I have not gotten under there to take a closer look yet.
__________________
1993 Ford Ranger XL Super Cab 4x4, 6" SkyJacker
3.0L V6, O ringed, copper head gaskets, ARP studs, Camcraft cam, JBA headers
5.13's, ECTED front, TruTrac rear
P285/70/17 Mud Claws, Black Rock 17x9
evanesce69 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Discount Code: 01783FE29A6986 Expires: December 30, 2018
Old 12-16-2017, 04:45 PM   #12
dirtcowboy
dirtcowboy's Avatar
Vehicle Year: 1985,1986(2),19
Vehicle Make: FORD
Vehicle Model: '85,'86,'86,'88,89, BII's 2002 F-250, 2003 F-150, 2004 Explorer
dirtcowboy will become famous soon enough
Default
Please post a pic when you get your D50 chunk installed. On my '89 BII there was zero clearance 'tween the D35 chunk and the 6" drop bracket/pass beam assemblage. Much judicious grinding followed.
__________________
"We're bad guys...it's what we do" Harley Quinn
Furthermore, I consider that islam must be destroyed.
dirtcowboy is offline   Reply With Quote
Old 12-17-2017, 02:39 PM   #13
evanesce69
evanesce69's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
dirtcowboy - will do my friend!
__________________
Old 02-13-2018, 09:45 PM   #14
Jim Oaks
Administrator
Jim Oaks's Avatar
Jim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond reputeJim Oaks has a reputation beyond repute
Default
What's the status on this? Have you taken care of the passenger side axle shaft issue, or made any decisions about the coil buckets?
Jim Oaks is offline   Reply With Quote
Old 02-16-2018, 09:46 AM   #15
evanesce69
evanesce69's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
Jim- Picking up the D50 chunk tonight after work. Going to bolt it up to the
beam and measure for the right side axle.. Stock D44 is too long and D35 is too short, 4" difference.... I figure I'll split the difference
Besides, bolting the D44 beams onto the Ranger mounts narrows the track by 2 inches... which just so happens to be the center of the two stock right hand inner shafts...
I'll post some photos of the D50 this weekend.
__________________
Old 02-17-2018, 06:48 PM   #16
Jim Oaks
Administrator
Jim Oaks's Avatar
Default
Thanks for the update!
Old 03-04-2018, 11:48 AM   #17
evanesce69
evanesce69's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
i have posited updated photos in posts 2 and 3... the center chunk on the bench and in the truck., photos showing how much to shorten the inner shaft
the shortened inner shaft is being sent to Moser for making a new one. also going to have CTM u joints put in the differential joint (1350 style) and the outer joint with new short stub
__________________
Old 03-04-2018, 09:13 PM   #18
Jim Oaks
Administrator
Jim Oaks's Avatar
Default
Looking good. Thanks for the update!
Old 05-02-2018, 11:32 AM   #19
evanesce69
evanesce69's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
I've got the front end together. I'm going to resize all my photos so that I can post more pics. Had Moser Engineering make a custom length right inner shaft along with the left inner and both outer. That are all 4140 chromoly with CTM u joints installed (PNC144-1881).
__________________
Old 05-03-2018, 06:07 AM   #20
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
i am shocked one would not simply install the d44 ttb at normal width....ESPECIALLY using these quality brackets...you simply add a hole drilled inboard on the front bracket and the rear slightly re positioned with new holes in the k member to keep the max advantage of no custom parts install. shocked is definitely not overkill to describe it.
i plan to build another ttb truck with the intention to run it in the emc challenge as a 4600 vehicle if that competition still exists once competed. i caught flak for that among-st a group of peers i consult with.
i can see limiting the rbv to 4cyl and 6 cyl as fair, but i should be able to build whatever 4 or 6 cyl i want... my only issue originally was having to keep the cologne engine as i would rather run the cyclone....but the engine block and transmissions have to be platform origins....there is no boost or power adders allowed as these rbv were always n/a.
well i assumed it also had to stay ifs, and iirc it did initially and the rules i guess now allow any axles (have not looked careful at current rules)...just have to have leaf rear and coil front like the original platform.
so to use ttb in the eyes of my peers is stupid...links and coils on a 60 are the easy button.. so i will have to really have a look at the current rules.
though in any case i still want to run a ttb.
Quote:
sounds like you have a drop plate...which actually can make swapping in a d44 ttb easier depending on your ride height goals and intended use.
Quote:
and this brings me to my reason to take time to post.
first thing....thank you for taking the time to document your choice of process. i do not mean to knock what you have done in any way. if it comes across as insulting it is not intended.
i assume you wanted max strength and to narrow it a bit if possible to keep the tires inboard as much as you could. i have done several variations of this over the years and prefer to be able to use easily sourced junkyard parts...especially axleshafts which i fawk up regularly.
you dont seem to be in for max travel and speed so i can see this working out good. but a trans yoke can really make a difference running the 1350 style joint for more engaged travel in the slip spline. the d50 is not made to move much in its leaf congiguration so the spline area is not too much if your running hard with long travel....
but the ttb 44 can be outfitted with rcv shafts...(which drew the fire on me) in the oem configuration as bolt ins. and regular shafts are still readily available for it...so the kick in the balls i was getting along with laughing and pointing was i can drive to the junkyard and buy/ bolt in a d44 for under 200 bux and no custom parts save for home mods to the pivots, and then spend 2 thousand on rcv axleshafts.... but the nice thing is junkyard shafts...easy to get and very cheap.
it makes sense to me
your choice of taking the cheap and easy out of this scenario having to mod the axleshafts perplexed me...i even used all 3 of my brain cells last i looked to do that with all ctm with max travel setup exceeded 1300 for something i knew would break quickly if i was in a steering situation.....so 2 k for the rcv seemed a better way to go because they are stronger full lock steering then even the bad ass setup you have with wheels straight. of course if your under 600 then i would have to say that is fair way to go.
inboard coil mount on beam for better articulated travel on the trail or outboard the buckets for stability. if it is a long range driver/trail machine i would never use coilovers personally
the ol f250 shock tower mount on the frame and just do a mount on top of your radius arm like a normal ttb 150 to get the brake clear of your shock.
either way, its is really appreciated that all the ways to skin the cat are getting covered. i am not one to take the time. great work on this
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ford Ranger: Module Install Jetchip JET Performance Products 0 10-28-2015 12:44 PM
DIY: Ford Ranger Double DIN Install TheTwanksta Stereo & Video 19 01-14-2015 01:46 PM
2007 Ford ranger air bag install help 07LoanRanger 3.0 Liter Forum 3 01-23-2013 01:00 PM
98 Ford Ranger Custom Install win1 Stereo & Video 4 05-24-2008 12:14 PM
98 Ford Ranger Custom Install win1 Stereo & Video 3 05-19-2008 05:21 PM
© 1999-2018 / 959 Media LLC / All Rights Reserved
