torcity
- Sep 9, 2013
- Reaction score
- 0
- Location
- Toronto
- Make / Model
- Ford
- Engine Size
- 3.0L
- Manual
Hey there, First let me start with a quick history of the truck...
I bought it about 2 months ago, and it wasn't running at the time. It had been sitting on blocks for 7 years without being run once, but was parked in good condition, with only 152 000km.
I payed $900, and went out to buy a fuel pump, and got her running. I drove it across the country, 5000km in total. Had to replace the thermostat 3500km into the trip when I realized it was stuck open... should have done it earlier i know.
About half way into the trip the engine started getting a rumble to it, and the previously smooth exhaust stream was now sputtering. Most notable at idle, but present in the entire rpm range.
My exhaust smells sweet, and although there isn't much smoke, some is present at startup. There are no bubbles in my radiator overflow, but the coolant is being contaminated with oil.
So yesterday I began my top end rebuild...
Most everything came off smoothly, although I did break 2 or 3 exhaust studs, which is a real PIA because my local Canadian Tire doesn't even have the part listed. I guess I'll grabe some grade 8 (right?) studs from the hardware store.
The gasket material is seriously stuck onto the heads, cleaning it is proving to be a nightmare. I can't find an obvious cause of the coolant leak from the head gasket, but all around it looks pretty burned. Gonna clean er till she's shining cause I'm kind of OCD like that... If I was smarter (and by smarter I mean less broke) I would have the heads resurfaced, but that's just not an option at this point.
The inside of the intake manifold is quite oily, and I'm wondering what the cause would be. The PCV valve is confirmed to be functional, although I purchased a new one to replace it anyways. I'm thinking it's either blow by, or some egr issue. I am admittedly unfamiliar with egr systems. I learned everything I know about cars from rebuilding my '76 MGB, so EFI and EGR are both new to me.
I noticed that it has roller rockers as well, is this stock? or has this motor been upgraded? I did notice that there were no exhaust gaskets at all, just metal on metal, so it has been opened up by someone I guess.
