1992 4x4 daily driver low budget build
IdigAUinNV
14
Rural Eastern Nevada
Ford Ranger XLT
I'm considering a 1 inch body lift myself. While it use to be available as a kit... no longer true. There are shops out there... even ebay that sell 1 inch aluminum pucks. I've read that 1 inch requires no other alterations. Slip the pucks in... tighten them down... done. No radiator/hose/shroud issues... no filler hose... steering shaft... wire harness... and the bumpers stay where they were meant to be. It does end up with a bigger gap at the bumper... but livable.
Rangers come with 9 or 10 inch brakes. Typically 9 inch on the 7.5 rear end... 10 inch on the 8.8 rear end. You will have to check the door tag... and look in the Tech Library for your axle code.
Door tag indicates an 8.8” rear with 3.73 limited slip. I was happy to see that as it save me from a gear change or other updates to diffs, and brakes should be good to go. Just inspect and repair if needed.
That should leave some room in budget for Bilstien shocks all around!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
nice truck to work with...
IdigAUinNV
14
Ford Ranger XLT
The auto hubs are cam actuated so nothing external like a vacuum line, they rely on friction between the plastic cam and the wheel bearing nut to actuate... they rely on the axle shafts spinning and both tires being fairly attached to the road to work so with an open diff and one tire stopped like if you're stuck it won't engage... and they break because changing directions I believe they disengage then reengage so if you're rocking it there's momentum...
They should fit on the stock wheels, some tire shops get cranky mounting wide tires to narrow wheels but a '92 should have wide enough wheels...
Shows my lack of knowledge as far asRangers goes!
Most if not all of our Super Duties I worked on used vacuum to operate the front hub locks.
Thanks for clearing that up.
IdigAUinNV
14
Ford Ranger XLT
I order my tires online and mount/balance myself. Got real tired of paying $50/tire locally for that. Small rural town with limited options and a take it or leave it attitude of many local businesses forces me to do everything I can my self.
IdigAUinNV
14
Ford Ranger XLT
I'm thinkin fresh HD springs all around... a 1 inch body lift on 31's would be a pretty sweet spot and keep your budget from creeping.
Cool project... have fun with it.
Concerning HD springs, any recommendations for a source and/or part numbers?
And would I need a separate leveling kit to make it look right?
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just bought a set of 1750lb rear springs for my truck. I ended up buying them from a local spring shop. They were about the same price as buying on the internet and shipping. I like to spend local when it's possible.
Moog has always been my choice for suspension parts... but these days all parts are really a buyer beware thing.
I think a little rake is good in a truck. It levels out with a load exactly like intended.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
There is what's called a "washer" lift for the front.
And it seems I just saw someplace that was making a "puck" that accomplishes the sane thing... but I can't find it now.
Look in the Tech Library for the washer lift article.
If I find the lift pucks I will post a link.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Then remember... any lift will require different length shocks.
You said Bilstien... mighty fine shocks. They're not cheap though.
I've been eyeballing Skyjackers new offering. The BlackMax. Check them out on the Skyjacker site... cone in different lengths. They had a rebate the other day... with that... would probably be half of a set of Bilstiens.
IdigAUinNV
14
Ford Ranger XLT
I did find a place that sells UHMW-PE pucks in almost any size you may need. I submitted an inquiry asking for more info. Mikellis Body Lifts is the name. They sell on eBay also.
I would have posted link, but not sure if allowed.
IdigAUinNV
14
Ford Ranger XLT
Nobody local for the springs, 3.5 hours minimum travel. So likely be buying online.
I agree with the Moog comment. Always my choice in past, but like most other companies, they have sold out their values to make a few extra $$, their name means little anymore.
Did you need to change the shocks for the HD spring install?
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Stock length shocks are fine until you lift it... front or rear.
IdigAUinNV
14
Ford Ranger XLT
I've been eyeballing Skyjackers new offering. The BlackMax. Check them out on the Skyjacker site... cone in different lengths. They had a rebate the other day... with that... would probably be half of a set of Bilsteins.
Bilstiens mighty proud of their shocks, but it only hurt once! Been very happy with installs on my personal vehicles.
I will check out the BlackMax shocks, but I’m likely to go with Bilsteins.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Just doing my part to keep you on budget!!
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
