3 Scientific Experiments to Settle This | Wide vs Narrow Off-Road Tires - Tinkerer's Adventure
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
JoshT
1,734
Macon/Fort Valley, GA
Watched that the other day. Good experiment for what he tested and his applications, but he missed and/or ignored a few things that I think are important.
  1. Used the same wheel between different tire widths (315 & 255 Baja Boss). Putting the wider tire on the narrower wheel is going to affect contact patch, he should have used the wider tire on a wider wheel for more acurate test.
  2. When he compared the two wide tires (315 Baja Boss and KM2) they appeared to be on different width wheels, plus the beadlock would affect how they are allowed to flex on respective wheel. Same width tire should be tested on same width wheel and same beadlock/nonbeadlock.
  3. Compared worn/broken in tire against new tires. Broken in tire that's been run at low pressures is likely to have more flexability than a new tire. Adding the used KM2 skewed the data, should have compared all tires in same general condition.
  4. Ignored terrain variables. To be fair he said from the start that this was about the surfaces he runs on which is rockly terrain. Mud, snow, and sand are going to have different tire requirements. How they contact the tire is also going to be different than a solid surface like rocks. The tire needs to conform to the shape of the rock, where as the mud and sand are going to conform to the shape of the tire. Snow is something completely different.
Regardless of the testing results I'm going to go for style first on mine. The F-100 needs tall narrow tires, the F-250 needs a wider tire. Having said that, both are currently running the same tire (size, brand, and model). About stock size on the F-250 (I think), oversize on the F-100. Measure about the equivalent of a 32x10. Next time around the F-100 might go taller, definitely more agressive on tread, and probably about the same width.
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I found the video interesting and the feed back is appreciated.
For me, I'm kind of locked in unless I change rim sizes. I can't find anything more narrow than the 31X10.5R15s I'm running on the 2011 and I have to be real careful what I put on the 2019 due to clearance issues with the suspension on the 2019, which are about 31.5" if I throw 265/70R17s on it. And I don't want to lift either one of them.
JoshT
1,734
If you're set on keeping 15s for the 2011, I think the narrowest you can get is probably a 31x9.5. Interco makes some tires in some odd sizes you don;t find anywhere else, and they make the TSL in that size. Veryt agressive tread and probably not what I'd want to run on a street driven Ranger.
If you are willing to step up to a 16 and metric tire you can probably find more tires in the ~31" diameter ranger that are narrower and more suitable for a street driven truck with an AT tire.
I like using this site when I'm trying to figure out potential tire sizes and what is available for a given size. Probably doesn't show everything available, but covers a lot of whats out there.
Josh B
1,986
Oklahoma
That's kinda why I didn't comment Josh, there was just too much tech with too little results I got bored with it but scanned across it anyway in little tidbits.
I actually decided a long time ago the widths all had their place, actually from a great uncle telling me about the Dallas-Houston highway, before they had highways, in many cases through East Texas was just some deep sand.
He told me about the big wide tired Buicks getting stuck, and the the skinny tire Model T's pulling them out, that was enough said for me
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Unfortunately in the world we live in scientific experts often reach a conclusion based on the narrative desired.
Too many variable were not addressed or were simply ignored. Rim width, terrain, tire compounds, even rim diameter.
X being a scientific factor for the unknown, and a spurt is a drip under pressure.
IMO.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
That came across my feed a few days ago. But I didn't watch it. Glad to read everybody's take on ot here.
The real problem is that it takes some deep pockets to do a real ture comparison. When your talking about $800 on up for a set of tires, then add in different size wheels to keep the geometry right. Then you need equipment to miunt/dismount tires, or lots of money to have a shop do it. Then you need time, and even some assistants to go out and do the testing, trying different terrains, making sure you drive the same way each time, collecting and analyzing the data, blah, blah, blah.
It's very difficult for unsponsored amateurs to do meaningful tire comparisons.
17,848
SW Iowa
Impossible to settle.
Way too many variables for a blanket statement of any kind.
You can test to your little hearts content and find the perfect tire for the terrain you are on at the moment. And then the sun comes out and dries the sand or it rains and everything is completely different.
Even fuel burn will effect balance and traction.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
I'm pretty sure we can all agree for real world offroad performance sidewall is king over the rubber bands the bro dozers put on their useless things they call trucks...
I like the setup on my '90, 35x12.50-15 on 8" wide wheels, not the best at anything but works well for my needs
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
My rule of thumb:
If there is a bottom under that mud or snow, = narrower is better (helps you dig down to that bottom for more traction)
If there is no hard bottom, = wide tire to help float on top of it as much as possible.
Sand = wide tire.
Rocks = narrow or a medium-width tire.
Select a tire that is based on what type of terrain is most prevalent in your area/terrain you most-frequently drive on.
17,848
SW Iowa
My rule of thumb:
Sand = wide tire.
All I ever do when I dig down to the bottom in snow is throw frozen dirt, I kinda think the theory is a little overhyped.
2011Supercab
467
Washington
Toyota Tacoma
My rule of thumb:
Sand = wide tire.
At what depth do you decide the snow is too deep for narrow tires ?
ericbphoto
16,598
Wellford, SC
6"
That’s more of a “time” than a “depth”. And the time is, right after you realize you’re hopelessly stuck and need a shovel and some ice melt and a tow truck.
17,848
SW Iowa
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I have found that thinner tires do perform better in the ice and snow than wider tires. The type and tread pattern also makes a difference.
A few people I worked with had vehicles with wide tires that were absolutely horrible. The wide tires make great toboggans.
