ekrampitzjr
- May 28, 2021
- 1,067
- Virginia
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
The pros run very wide tires on ice and snow at low PSI, sometimes < 10 psi. Of course, they're moving at very slow speeds.
Then for the loose sand that's common on the Outer Banks of North Carolina those with permits use wide tires and reduce tire pressure to < 20 psi. The Outer Banks south of Nags Head were notorious for vehicles getting stuck in sand until the paved roads were built starting in the 1950s. That sand is still very loose. Cars that pull over to park by NC route 12 on Pea and Hatteras islands still routinely get stuck.
The tire pressure is as important as the tire width.
