4BT '94 Ranger & EB D44 SAS (no56k)
Cummins_Ranger
Jersey
3.9
new motor mount brackets & isolators.
Ride height- Head lights are at chest level....
yes im missing a U-bolt, wasnt big enough to fit over the diff
ordered new radiator get a little better flow, and have to make a new t-stat housing bc the old one that points down leads right into my motor mount bracket. next step is removal of stock gas tank and get the t-case mocked in place to ensure front pinion is set before final welding the perches and spring mounts.
still not sure what im going to do for track bar...as you can see in the pic its way to much room under there height vs. width to fit one. probably do a coil over style shock and have them valved a little stiffer, maybe that will work?
jwestra
stevens point
any updates on this? and may i ask why you didnt use coils and radius arms on the ebd44?
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Yeah, whats going on Dave? That reamer work out for you?
Cummins_Ranger
Jersey
3.9
i was going with coilovers, but the company i was going to purchase from had a warehouse fire and everything was lost...soo thats when i decided to go leaf. as for the reamer, i havent had a chance to get the front axle out to ream them out :sad: only thing that has changed since beginning of march is the rear is all out. and the front is all tacked in sitting on tires.
more pics of to where i am at;
and my toy in the last pic needs to be taken out, so that means another weekend of no work on truck... but things are slowly getting there!! :icon_thumby:
89Ranger5.0
Upstate NY
5.0 302
Been following you on a few forums so subscribed here. Nice work
Cummins_Ranger
Jersey
3.9
thanks man. there are a few shows im trying to get it to this summer, so it has to be drivable by end of May i believe. should be attainable if work doesnt get crazy again. as for bigger turbo and injectors, that part of the build may not happen till winter. along with interior
Cummins_Ranger
Jersey
3.9
update time;
got the GM 1 ton TRE and got 1 made up
old next to new
this will be ride height
t-case blocked to its almost final position
going to cut the brackets for rear springs this week, axle is currently just sitting in place. Along with that i will have the 2 crossmembers for the t-case cut and hopefully welded in this week, so i can finally mount the t-case. using 2"x4" 3/16" rect. tube for the crossmembers, and same for the 2 existing crossmembers down near the rear axle. also going to box the frame fully.
Josh40601
MTOTM Winner
12
San Diego
Ford78
December 2012 OTOTM
Iowa
351w
That loooks awesome!! doing one hell of a job!
Cummins_Ranger
Jersey
3.9
thanks! I am actually behind schedule, work has gotten busy and has been keeping me from getting what i want to get done on the truck. hoping to have it on the road again soon, definitely has to be done before august b/c it will be at the truck nationals at carlisle.
1994_4x4
Ohio
Lot of questions
What is HP rating on that 4bt?
What transmission did you use?
Is that a 205 t case?
Cummins_Ranger
Jersey
3.9
105 or 120 depending on pump
M5R2 '97 f150
yes ford divorced style
Josh40601
MTOTM Winner
12
San Diego
So you used a 2wd f150 trans then?
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Yes he did. His truck started life as a 2wd.
Cummins_Ranger
Jersey
3.9
yea, i could of swapped but i bought the trans new n got a good deal on it. then found the tcase out in pa for reasonable price so i snagged it instead of running a married setup. trying to get the thing mounted by end of the week, just hoping work stays calm n it actually happens....been saying it for 3 weeks now lol
