Well the thing is it's not really any extra money to spend anywhere. The 5.0 runs the EGR off ports through the head, direct from the middle valves. My heads and intake have the passages, it's just a matter of which carb and plate I get, which are parts I need anyway. On the other hand, I have never seen a carbe'd engine with EGR that ran quite right.
Cats are pretty much a must in my mind. A pair of good universal high-flows will only cost $200. Three-way cats can pretty much take care of all the Nox on their own, without any help from EGR. Or tune it a little rich so it stays cool. Then it wouldn't be making Nox anyway.
As for the laws, I know the laws. PA state law says it only has to have what it was built with, and it has to look like it could work. 1974 and older, or if it is driven less than 5000 miles a year (which this car almost certainly will be) anything goes.
First year that cats were mandated was 1975, and federal law says 1975+ must have cats if it was built with them. There were a few years after 75 that Honda managed to get the Civic to pass Federal tailpipe without cats. I think the Civics got them around 1980.
Anyway, progress...
Paint:
That pic doesn't show it very well, but the valve covers look terrible. They were grey, then someone painted them blue, then someone pretended to paint them red, and must have gotten bored halfway through and quit. The paint was in bad shape, so I took a wire wheel to them this morning, cleaned off what flaked away easily, got the rust off for the most part, brought them back and painted them. They look terrible. You can easily see where a section of bare metal abruptly goes to 4 layers deep, and the paint is so thick over the logos that you can barely see them. I will be taking them down to a local coating shop to get them sand blasted this week, then start over.
The oil pan, which I won't be nearly as picky with because you can't see it, looks 100x better than the valve covers.
Front cover and oil pan got their color coats and shot with clear already today. They should be dry enough to install in about half an hour here.
Mechanical progress:
Put bell on trans so it doesn't get lost. Last time I lost the bell was 2007. Just found it last week, in the trunk of the car.
Heads are clean, installed, valve train together, dog-bones and retainers in. Yes, it is upside down for a reason. I didn't look closely at the intake mating surface before installing the heads. There was a lot of really baked on intake gasket right around the EGR ports and water passages. Some (pronounced "a lot") of that stuff fell into the valley. I am going to blast it out with some brake cleaner and air later. Just letting stuff fall out for now.
Timing drive all together, oil pump in.
