atomicjoe23
- Oct 3, 2008
- 0
- Ford
Thanks JoeCool85
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I appreciate it. I completed my part of the thread, but I'm not the OP - that was AtomicJoe. I'm assuming his truck isn't fixed yet.Good job, and thanks for the update and "completing" this thread. Glad you found the culprit. I'm gonna rep you now.
How did you end up determining it was bad. . .I'm going to go check my sensors right now.Ok, ended up being my ABS speed sensor on the rear axle. $15 from Advance Auto and I'm good to go.
That said, people need to stop referring to it as the VSS (vehicle speed sensor) because it confused the heck out of me. It's the ABS Speed Sensor, the VSS is on the transmission and is a different part. THAT is why the speedo will keep working even when the sensor on the axle is bad.
There is a wiring harness coming off from it that is a foot or two long, comes in front of the wheel (both sides do this) and hangs between the bumper and the front of the wheel. Disconnect this clip and you'll see two electrodes.How exactly did you check the resistance on the front ABS sensors??? There doesn't seem to be a quick disconnect, at least not close to the sensor itself. . .all I can see is a small metal "pole" at the end of the sensor itself.
Thanks!
Resistance between the two electrodes in the plug not the socket. IE - the wire going towards the hub not towards the rest of the truck.So do I check the resistance between the two electrodes or the resistance between the metal pole on the sensor and the each electrode separately?
I tried both methods and I didn't get any readings. . .as in the display on the multimeter didn't do anything regardless of which scale i was on, and yes I was using the ohm section of the multimeter.
That's what I had it set on initially, when I didn't get a reading I went up the scale with no luck.Resistance between the two electrodes in the plug not the socket. IE - the wire going towards the hub not towards the rest of the truck.
Your multimeter should be set on 2k (2000) ohms. Are you sure your meter is working?
I can get a used rear sensor out of a 2000 Mountaineer for free this Saturday. . .I will try that before I buy a new one.**edit**
I have a hard time believing that BOTH your front sensors are reading 0 ohms. That said, even if they are I would spend the $15 and swap in the new rear sensor first since it is so cheap and is probably the failed sensor anyway.
Everything is smooth during low speed turns so it probably is the rear sensor then. . .Also, apparently when one of the front sensors go your ABS will pulse when you are on the brakes and turning sharply at low speed. IE - 10mph turn to the right most of the way and apply your brakes, then the same to the left. If everything is smooth it's probably your rear sensor that is bad.
There was no "L" just 0.I'll bet the reading he got was not zero ohms, but it was OL, the usual digital display for a resistance too large to measure in the range selected. IE the resistance reading was infinite or open circuit.
What does the meter read when it's set in the ohms mode and not connected to anything?That's what I had it set on initially, when I didn't get a reading I went up the scale with no luck.
