cheap suspension lift
akers4291
Rhode Island
i really need to lift my ranger nd i want to put a 3in or 4in suspension lift on but they are really expenise... is there any cheap ways to doin this
GB4000
NJ
Mazda
I have an 04 and I wish there were but unfortunately I have yet to find one.
engdept
5
Charlestown, IN
2.9
You can do a 3" body lift for about $200.
akers4291
Rhode Island
ya idk tho about the body lift... can someone explain to what torsion keys are
engdept
5
Charlestown, IN
2.9
junk, if you want to save money and get a 3" lift, go with a body lift. There is nothing bad about them.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Crank the stock bars and add a body lift. This will let you run a 35" tire if you want. Aftermarket keys are a waste of money.
engdept
5
Charlestown, IN
2.9
Yea I don't think so; a 33" tire, but not a 35.
akers4291
Rhode Island
i am running 31x10.50 but i want 2 go bigger already
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
With the amount of guys running 33's with just the bar crank and a few running 33's stock, 35's will fit with the body lift and bar crank....just look around the forum......
tbar crank, 3" body lift and 35" procomps
What ever happened to Ranger Interceptor by the way???
engdept
5
Charlestown, IN
2.9
I wouldn't run 35's on just a body lift, not enough room for suspension travel and you have to remove your front bumper or do major cutting.
akers4291
Rhode Island
ya i would go up 2 a 35 i would stick with the 33 but i want 2 take the frount bumper off nd biuld my own
mwood1985
7
Marietta GA
4.0 SOHC
body lift and tires
i beg to differ on the biggest you can run being a 35 this is a sampling of my buddy donnys 2004 with a 3 inch body liftand no i repeat NO tbar crank or suspension lift . those are 305 85 R16 buckshot maxis mudders. not one problem with rubbing or any clearance issues
mwood1985
7
Marietta GA
4.0 SOHC
bajamazda
Canada
Mazda
doing a body lift isnt going to really give you more ground clearance the better way to go would be a level kit 2" in the front and a 2.5" block in the rear then torque the bars to level it up to 2.5" in the front the less amount of torque you put on those bars the longer they will last ive broken torsion bars it doesnt take much when there is any amount of extra torque on them then run a larger tire then look at a body lift after the body lift arnt bad cost wise but if you arnt putting it on yourself the labour behind it may scare you. hope that helps at all cheers
MastuhWaffles
11/2014 OTOTM Winner
69
Texas
4.0L SOHC
I need more sleep.
I cranked my T-bars and I have 31's, I still have LOADS of room.
No members online now.
