Chopped Top B2 on Wagoneer chassis
crisd
37
Thanks for the Jegs tip, I'll probably buy their kit then expand from that.
crisd
37
I now need to address the front drive shaft issue. It's too short now. I'm thinking of just buying a longer slip yoke. The oem piece is 7" long. I haven't found a shop that sells longer ones, anyone know of where I can order one?
crisd
37
I also installed a clocking ring to rotate the transfer case down a bit... right into the transmission cross-brace. So I had to discard the old one and make a new one that sits lower with a higher perch.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
how did i miss this?!?
very very kewlz.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
is that a 229 case?
crisd
37
is that a 229 case?
Yes, that is a 229 T-case. Is there something I should know about clocking it down? Am I going to have lubrication problems?
crisd
37
This is the new transmission cross member. Each side sticks out real far right now as I'm considering using it to also support side steps. If that idea later sucks I'll cut them down.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
they are fairly robust for a light fulltime capable case. just make sure its full. i prefer to use the 208 version in v8 ranger swaps because they work really well and are captain caveman simple.... light and a good size.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I was looking up info on the 229 TC and found this page. It might be helpful for you... I don't know if it covers everything for your chassis but it does cover the 229.
Tom 'Oljeep' Collins homepage
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
