eliminating the ABS from my truck
stegomon
20
auburn/minot maine
fords and only
When did they get away from the tcase speed sensor. My 97 uses the tcase
Derrick1970
Iowa
Triton V10
I believe it was in either 98 or 99. Correct me if I am wrong there guys. The 99 Explorer I got for my donor vehicle has the sensor in the rear end.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
98 was the changeover year, some had it, some didn't...
SVT
don4331
1,353
Calgary, AB
5.3
Doesn't Ranger go back to transmission/transfer case OSS sensor in '01.
'88-94 mechanical
'95-97 VSS in transmission/transfer case
'98-00 RABS/VSS in rear differential
'01-11 OSS in transmission/transfer case
SenorNoob
588
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
There is a VSS in the transmission/transfer case for earlier vehicles. My '88 had one. I'm still using it with the 92 ECU. The speedometer is mechanical still though.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
'88-94 mechanical
No, as of 99, the vss (vehicle speed sensor) uses the rear axle tone ring used for abs (abs sensor sends signal to abs module, signal gets corrected and sent to ecu/instrument cluster - not the exact method, but for descriptive purposes). The oss (output speed sensor) is not used for the speedometer, it is used to determine slippage in automatic transmissions...
SVT
