Bryan22
- May 2, 2008
- 4
- Age
- 39
- So-Cal babay
- 94 extd
- Ford
- Engine Size
- 94 2.3
To answer you're question, YES! changing the sensor, if that is what the problem is, involves taking out the 2 small bolts on top (5.5 mm i think) and pulling the sensor off and changing it. But, that might not be the problem. last time i had a problem with it, the piece that actually passes through the sensor came apart from the shaft. So i had to replace the whole assembly, which is a pain in the but.
Also you could have a problem, like Scott suggested, with the timing of the sensor. only way to time it is with the engine at TDC take the sensor off the "synchronizer" and align it with a special plastic tool. But, you can just eyeball it to see if it's way off or not. if you take the sensor off, there is a gap in the housing, at TDC i think the wheel is about 20 degrees past the gap. if it's obviously off you'll know that's the problem. If it looks pretty close and the synchronizer is in one piece, it' probably the sensor.
Whew, hope that help. If you get online and look for a picture of the tool you'll have a better understanding of how things should be aligned.
