Not planning to dual tank. I found that my tank was rotted out. I want the space on that side of the truck to run my dual exhaust, and wanted to move more weight to the rear of the truck to help with weight and balance (going to 5.0L). So while brain storming on what to do about a tank I setteled on the idea of a running a BII tank behind the axle, with the filler for it in the same location as a factory dual tank Ranger's rear tank filler. It's cheaper than a fuel cell, and can be made to accept the explorer's in-tank fuel system components. I'll give me larger range due to greater capacity, which will also add weight to the back helping with traction. That said I think I've decided to stick with a rear bumper. It'll go better in the overall sleeper look I want to achieve, though the 17" Mach 1 wheels may kill that idea.
It takes a lot of weight to hold the backend with a 4.0 so I doubt you could enough for a 5.0. I had dual evhaust on my other ranger so the stock tank location should be somewhat ok but yeah a bumper would add to the sleeper look.
Refering to this post?
The Snake Pit
That is the post!!
Don't know if I'd run that without match white face gauges (or did you do that already). Either way I think the white face gauges and HVAC panel would look great in your truck. Personally I like the black, but would get their silver ones (brushed or metallic) for my first gen if they had matching HVAC panel, only in white though. What I really want is a custom filter for the warning lights in the center of the first gen dash, add my own warning lights to match the engine swap.
