PlumCrazy's Build
PlumCrazy
2014 Truck of The Year
177
Millersport, OH
Solid Axle Swap 4x4
I never actually tried the SOHC pan in the TTB cross member though. I know some guys just shim the motor up .5" or so and it clears from what I hear.
Sent from my XT907 using Crapatalk
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
So are you going to get it done by this fall?
Sent from my SM-N910T using Tapatalk
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
Hope so. Dropped the block off today for machine work
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I'm hoping to get mine (HWW) done by the 4th of july if not sooner. It's been a while since I've been on the trails...
SVT
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Rick, you and Dustin get them running and I'll come down and wheel with you both
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
Made a little progress...
Burned out a flange for the new exhuast out of .5" plate. Still np ETA on the block though.
Also got the track bar whacked off....then I changed gears and started the OneFiddy 5 speed swap.
Also elimnated the fire hazard insulation on the HVAC plenum....pulled the old stuff off and bent up some aluminum to replace it.
Seals for the SOHC oil pan showed up too
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
Started toying with the idea of adding some lubrication to the pushrod end of the rockers.
Using some 1/4" OD tube and sweat on fittings I built a manifold that will pull oil from around the rocker shaft mounting bolt and drip over the rocker end.
I ordered some sweat on banjo fittitings, but they only come in 3/16". I drilled them to 1/4" and sweat everything together with 430* silver solder.
I clamped an air hose on plugged the holes to test for leaks under water..
Still need to drill the orifice oils for each rocker, then I will clean the inside and cap the ends. I will need to turn the shank of the bolt down a touch to allow oil to flow into the banjo. I will also be adding support brackets on the other two bolts...
I am using a high volume oil pump, so I should have more than enough flow without giving up any oil pressure. I also plan to safety wire the fittings and tubes just incase something fatigues and breaks.
I need to do a little math to figure out what size holes to put over each rocker. Im thinking .0125" should be good. The oil may or or may not even make it into the socket though....but I suppose extra oil showering on the rockers cant hurt anything.lol
escort_gts
16
Fort Wayne, IN
4.0, 5.0
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
I hate valve noise...and I was bored.lol
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I feel like you are the closest thing we have to a real Tony Stark.... So when will your Mark I Iron Man suit be completed?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Hows the progress coming? Heard from the machine shop?
SVT
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
SVT
Pretty much absolutely zero progress.....No word from the machine shop.
PS....your headers are in the trunk of my car...I put them there to take to work and box up.....2 weeks ago. I swear Ill get them out to you.lol
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Oh yeah, I forgot all about them. I'm about to start up on that project next week actually...
SVT
