PlumCrazy's Build
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
It really only took about 4-5 hours. Just need a grinder, dead blow, angle finder, tape measure, straight edge, welder and vise.
Sent from my XT907 using Tapatalk
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Yeah I assume it would be fairly simple but I have a hp 78-79 axel and a LP waggy 44. I've contemplated swapping the tubes so I can shorten it up like you've done.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Just shorten the 78-79. It would be super easy. Only one weld to grind/move
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Welded the tubes.
Tried on the new cover.
I'm a tire hoarder...
3,614
My basement/garage/backyard/woods behind the house is starting to look like that, only not as many matched pairs. And more holes in the side walls.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Yeah I've got 1 full set of BFG mud terrains 35"s, a pair of 35" wide brutes and a pair of 38.5" tsl's setting next to my shed. Soon I'll get my almost new set of 30" cooper stt's back for my 99 black ranger. I'm tire poor right now lol
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Had blast wheeling Clay Valley on the 4th. Mostly tight woods trails and slick hill climbs since this was only the 3rd event ever held here. Helped cut a few new trails and make a few more permanent.
The front end actually held together for once besides grenading a hub.
I also popped a front brake hose, I don't think I pinched it, I think it just popped under pressure? Having a tough time finding a replacement. 26" long with a 7/16 banjo and a 3/16 Inverted flare T on the other end.
I swapped my 45* fitting out on my steering cyl after shearing it off on my pitman arm...Im not sure why I didn't have a 90* on there to begin with.
I slapped on my pretty new sticker....and promptly went out and shattered it.
Picked up a new window at the local Pull-a-Part (shit is getting expensive there now a days) and threw some tint on it. I wasn't going to bother with tint...but it keeps the window together if it gets broken.lol
Forgot my gopro and was flying solo, so no pictures from the trip really.lol here is the aftermath...
After a quick bath..
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I stopped by Summit Racing on my way home from NY last week and glanced through the ole clearance section..
Scored a 5x5.5 15x10 Mickey Thompson and 25' of flexy flare for $50 bucks total.
Found a brand new 38.5 TSL for less than half of new so I picked it up to replace the one in my set that had some dry rot and a cut (still held air) Threw it on the bead lock and Ill throw the old one on my pretty new MT for a spare.
Old one..
My first order showed up...I can say RCV has some of the best customer service in the industry. They are willing to work with customers for sure and not try to upsell you every chance they get. I cant say the same for Yukon though...they ignore emails, don't return calls, and just are not helpful overall.
Picked these up cheap...Superior Super 88 semi-float shafts. I did some digging and found that even though Superior is out of business, the Yukon Ultimate 88 kit is a 100% knock off of their kit. Im trying to locate the rest of the parts, but I may just buy a new kit and use these shafts, then keep the others for spares.
I sold my Kevlars and rims, so I currently have no street tires, but it should motivate me to go through with my plan for 37s and bigger rims..and I got to help a fellow wheeler out in a pinch to get him back on the trails with a new Kevlar
That's all I got for now.
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
Im surprised you dont go to plexy ext cab windows.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
^I will next time. Lol. I can tinted frosted Lexan.
Sent from my XT907 using CrapaTalk
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
UPS man dropped off some goodies. Updated RCV joints that have the roll pin retainer to fix the stub walking out if the joint issue.
036speed
02/2013 OTOTM Winner
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Well, your 44 is going to stronger than my 60...
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
^We will see....
Bray D
2012 UA Ranger
8
Manito, IL
RCV's are quite appealing. I have two sets of chromos for my front end right now. Maybe someday I'll sell them off and commit to a set of RCV's. 1000 bucks isn't entirely out of the question. Stronger, smoother, and no need for spares.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I got a decent deal on these....I'll damn near break even when I sell my current chromos and spare set.lol
