tobyduck
- May 5, 2010
- Reaction score
- 0
- Make / Model
- Ford
- Engine Size
- 4.0
- Automatic
Intake manifold gaskets going bad, had to remake the gasket so it wouldn't go bad on the 4.0 due to the way it was made.
Cam shaft sensor on the 4.0.
No one seems to know what a flange gasket is in a part store lol, but those don't last for the lifetime of the truck either.
BLEND DOOR will break, and part store workers want to sell you the entire assembly. Idiots where I live...
My ABS system failed to work until I changed my brake shoes and bleed the system out.
Vacuum hubs.
Door handles will break off over time.
My dome lights blow out more than usual, probably my radio wiring though.
Instrument lights blow out over time, and one blew out right after I changed two of them. typical.
The oem speakers are not quality and need to be replaced after about ten years. common sense though.
Feedback in the radio due to the spark plug boots and wires. Grounding problems.
Cruise control buttons will deface and crumble up over time. $100 for a new pair where I live.
Engine gaskets seem to leak, like oil pan, valve cover, etc.
Random high idles due to air conditioner clutch.
Gear shift Indicator will move and be off a few mm or a whole gear
Vacuum hubs.
